Ga door naar hoofdinhoud
TiVo Series 2 TCD540080 Motherboard Replacement
Svyatoslav Markeyev
Svyatoslav Markeyev en 5 andere bijdragers
Voor het laatst geüpdatet op January 28, 2014
15 minuten
Eenvoudig
Wat je nodig hebt
Gereedschap
Toon meer…
  1. TiVo Series 2 TCD540080 Motherboard Replacement, Removal of TiVo Series 2 TCD540080 Case: stap 1, afbeelding 1 van 1
    • Power down the TiVo and detach the power cable from the rear of the unit.
    • Wait 5 minutes for the unit to fully discharge before proceeding to the next step.
  2. TiVo Series 2 TCD540080 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the five T10 screws from the rear of the case using the Torx screwdriver.
  3. TiVo Series 2 TCD540080 Motherboard Replacement: stap 3, afbeelding 1 van 2 TiVo Series 2 TCD540080 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Lift up and pull back the outer casing towards the rear of the unit.
  4. TiVo Series 2 TCD540080 Motherboard Replacement, Motherboard: stap 4, afbeelding 1 van 1
    • On the rear of the device, remove the right screw with a T10 Torx Screwdriver.
    • Unscrew the two black screws on the left with a T8 Torx Screwdriver.
  5. TiVo Series 2 TCD540080 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the white ribbon cable from the motherboard.
    • The black base where the cable is connected is not part of the cable. Do not lift up on it!
  6. TiVo Series 2 TCD540080 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Remove fan power connector.
  7. TiVo Series 2 TCD540080 Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Disconnect the hard drive data cable.
    • Use extreme caution when unplugging the connector and do not disconnect the data cable by pulling on the cable itself.
  8. TiVo Series 2 TCD540080 Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Disconnect the connector cable that goes to the lights on the front of the device.
  9. TiVo Series 2 TCD540080 Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Unscrew the four screws on the motherboard with a T10 screwdriver.
  10. TiVo Series 2 TCD540080 Motherboard Replacement: stap 10, afbeelding 1 van 3 TiVo Series 2 TCD540080 Motherboard Replacement: stap 10, afbeelding 2 van 3 TiVo Series 2 TCD540080 Motherboard Replacement: stap 10, afbeelding 3 van 3
    • Use a pair of needle-nose pliers to make the two tabs parallel with the open slots.
    • It is recommended that you do not bend these back after putting unit back together as they may break after repeated use.
  11. TiVo Series 2 TCD540080 Motherboard Replacement: stap 11, afbeelding 1 van 1
    • Pull the motherboard out towards the front of the TiVo unit, then pull up to remove it.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Svyatoslav Markeyev
135 Reputatie
5 handleidingen geschreven
Cal Poly, Team 33-79, Johann Spring 2010 Lid van Cal Poly, Team 33-79, Johann Spring 2010
CPSU-JOHANN-S10S33G79
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 4,478
