Ga door naar hoofdinhoud
This guide will show you how to get into the Thumby with minimal damage to the plastic casing
Wat je nodig hebt
Onderdelen
Gereedschap
Toon meer…
Deze demontage is geen reparatiehandleiding. Om je Thumby te repareren, gebruik onze reparatiehandleidingen.
  1. Thumby Teardown, Thumby Teardown: stap 1, afbeelding 1 van 2 Thumby Teardown, Thumby Teardown: stap 1, afbeelding 2 van 2
    • Insert an opening pick to the right of the Micro USB port, and slide it around the whole frame. Be careful with the top right and bottom left corners, as to not snap off the pins.
    • To take out the motherboard, pry up on the battery. It's securely glued in place and the least fragile component.
    • When removing the motherboard, make sure the screen is facing downward. The DPAD and A/B buttons are not secured to the front in any way, and will fall out if they have nothing supporting them.
    • To assemble the Thumby, you will need glue, unless you don't mind it barely holding together.
UnRedKnown
208 Reputatie
2 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 30
Altijd: 586
