Ga door naar hoofdinhoud
Texas Instruments TI-30 XS Multiview Solar Panel Replacement
Wat je nodig hebt
  1. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Open the device: stap 1, afbeelding 1 van 2 Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Open the device: stap 1, afbeelding 2 van 2
    • If the screw is not turning, do not force it. This can strip the screw. See the How to Remove a Stripped Screw guide if the screw is already stripped.
    • Using the #00 screwdriver, unscrew the six, 6mm Phillips screws.
    • Use the spudger to pry into the space between the blue back cover and the white body to take off the back cover.
  2. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Open the battery compartiment: stap 2, afbeelding 1 van 1
    • Using the #00 Phillips screwdriver unscrew the two, 3mm Phillips screws located near the top of the calculator.
    • Lift the metal plate from the battery and set it to the side.
  3. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Eject the battery: stap 3, afbeelding 1 van 1
    • Use the spudger to lift the battery up from the black holder.
    • Put the new CR2032 battery in. Never insert a different type of battery!
    • Reverse the steps 2 and 1.
  4. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Free the solar panel: stap 5, afbeelding 1 van 1
    • Use the #00 Phillips screwdriver to remove the one 3mm Phillips screw holding the solar panel in place.
  5. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Carefully pull the panel out: stap 6, afbeelding 1 van 1
    • Be careful not to pull the solar panel too far out, as the wires connecting it to the calculator are fragile and could be ripped off.
    • Carefully pull the solar panel away from the calculator, as shown to the left.
  6. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Unsolder the wires: stap 7, afbeelding 1 van 1
    • The capacitor might not be discharged. Proceed with caution.
    • Unsolder the three wires from the motherboard.
    • Unsoldering help can be found here.
    • To re-solder the wires from the new solar panel to the calculator motherboard take notice of the color and placement of the wires.
Conclusie
Aaron Feinstein
337 Reputatie
1 Handleiding geschreven
Cal Poly, Team 11-2, Forte Fall 2015 Lid van Cal Poly, Team 11-2, Forte Fall 2015
CPSU-FORTE-F15S11G2
4 Leden
9 handleidingen geschreven
Één opmerking
Do you know where I could get a replacement solar panel for the calculator?
Josh - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 2,421
