Ga door naar hoofdinhoud
Tefal Thick N Thin Toaster 815032 Inner Heating Panels Replacement
Wat je nodig hebt
  1. Tefal Thick N Thin Toaster 815032 Inner Heating Panels Replacement, Side Panels: stap 1, afbeelding 1 van 3 Tefal Thick N Thin Toaster 815032 Inner Heating Panels Replacement, Side Panels: stap 1, afbeelding 2 van 3 Tefal Thick N Thin Toaster 815032 Inner Heating Panels Replacement, Side Panels: stap 1, afbeelding 3 van 3
    • Turn the toaster upside down.
    • Remove the four 10 mm screws from the bottom of the toaster using a TR9 Torx screwdriver.
    • Remove the 14 mm Torx-slot combination screw on the opposite side of the toaster's lever with a TR9 Torx screwdriver.
    • Remove the 11 mm Torx-slot combination screw near the toaster's lever with a TR9 Torx screwdriver.
  2. Tefal Thick N Thin Toaster 815032 Inner Heating Panels Replacement: stap 2, afbeelding 1 van 1
    • Remove the side of the toaster that does not have the lever.
    • The side will just pop off, as you have removed the screw holding it in place.
  3. Tefal Thick N Thin Toaster 815032 Inner Heating Panels Replacement: stap 3, afbeelding 1 van 2 Tefal Thick N Thin Toaster 815032 Inner Heating Panels Replacement: stap 3, afbeelding 2 van 2
    • Remove the 10 mm screw from the top of the remaining side of the toaster using a TR9 Torx screwdriver.
    • This side will pop off as well once you have removed the screw.
    • The toaster's lever and heating slide will fall off with a simple pull.
  4. Tefal Thick N Thin Toaster 815032 Inner Heating Panels Replacement, Front and Back Panels: stap 4, afbeelding 1 van 1
    • Use an opening tool to pry back the metal tabs on the left and right corners of the toaster's front and back metal panels.
    • Pull off the front and back panels of the toaster.
  5. Tefal Thick N Thin Toaster 815032 Inner Heating Panels Replacement, Inner Heating Panels: stap 5, afbeelding 1 van 2 Tefal Thick N Thin Toaster 815032 Inner Heating Panels Replacement, Inner Heating Panels: stap 5, afbeelding 2 van 2
    • Pry back the metal tabs on the corners of the front and back inner heating panels using an opening tool.
    • Remove both the front and back inner heating panels of the toaster.
Conclusie
Kristen Gismondi
73.437 Reputatie
183 handleidingen geschreven
iFixit Lid van iFixit
Community
141 Leden
17.757 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 107
