Ga door naar hoofdinhoud
Surface Laptop Studio Battery Replacement
Nate Ball
Nate Ball en 3 andere bijdragers
Voor het laatst geüpdatet op March 25, 2024
10 - 15 minuten
Gemiddeld
This is a guide on how to replace the battery in a Microsoft Surface Laptop Studio. You may need to replace your battery if your device is unresponsive and won't turn on after charging it, or if battery life is short. You will only need a few tools for the repair and it only takes 10-15 minutes.
Wat je nodig hebt
Reparatieset
Deze set bevat alle onderdelen en tools om deze handleiding te voltooien.
Onderdelen
Gereedschap
Toon meer…
  1. Surface Laptop Studio Battery Replacement, Lower Case: stap 1, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Remove the rubber cosmetic strip along the outside edge of the back plate with tweezers.
  2. Surface Laptop Studio Battery Replacement: stap 2, afbeelding 1 van 2 Surface Laptop Studio Battery Replacement: stap 2, afbeelding 2 van 2
    • Remove the two rubber feet on the lower case with an opening tool.
  3. Surface Laptop Studio Battery Replacement: stap 3, afbeelding 1 van 1
    • Remove the two screws with a T3 Torx screwdriver.
  4. Surface Laptop Studio Battery Replacement: stap 4, afbeelding 1 van 1
    • Remove the seven screws securing the lower case with a T3 Torx screwdriver.
  5. Surface Laptop Studio Battery Replacement: stap 5, afbeelding 1 van 2 Surface Laptop Studio Battery Replacement: stap 5, afbeelding 2 van 2
    • Lift the lower case gently and set it above the device.
    • Take care not to strain the battery cable as you move the lower case.
  6. Surface Laptop Studio Battery Replacement, Surface Laptop Studio Battery Disconnection: stap 6, afbeelding 1 van 2 Surface Laptop Studio Battery Replacement, Surface Laptop Studio Battery Disconnection: stap 6, afbeelding 2 van 2
    • Disconnect the battery cable by lifting the pull tab until it "clicks."
  7. Surface Laptop Studio Battery Replacement, Battery: stap 7, afbeelding 1 van 2 Surface Laptop Studio Battery Replacement, Battery: stap 7, afbeelding 2 van 2
    • Pull the pull tabs to release the adhesive securing the battery.
    • Remove the battery.
    • You will need to reattach the new battery with adhesive.
Conclusie
To reassemble your device, follow the instructions in reverse order.
Één andere persoon heeft deze handleiding voltooid.
Nate Ball
690 Reputatie
5 handleidingen geschreven
3 opmerkingen
Where can I find a Surface Studio Laptop battery? Microsoft seems to have been out of stock for a while now.
Omar Abouelseoud - Antwoord
Are the rubber feet re-attachable to the laptop after repairs?
Any link to buy the battery ?
Alberto Guinea (Shlenderman) - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 87
Afgelopen 30 dagen: 307
Altijd: 7,200
