Ga door naar hoofdinhoud
SteelSeries Nimbus+ Triggers Replacement
Wat je nodig hebt
  1. SteelSeries Nimbus+ Triggers Replacement, Remove the phone mount: stap 1, afbeelding 1 van 2 SteelSeries Nimbus+ Triggers Replacement, Remove the phone mount: stap 1, afbeelding 2 van 2
    • Use your fingers to remove the phone mount by pulling it straight out of the controller.
    Vraag FixBot
    Voeg opmerking toe
  2. SteelSeries Nimbus+ Triggers Replacement, Remove the sticker: stap 2, afbeelding 1 van 1
    • Use your fingers to remove the sticker located on the back cover of the Nimbus+.
    • If you have trouble removing the sticker heat an iOpener and apply it to the rear case for two minutes to loosen the adhesive underneath.
    Vraag FixBot
    Voeg opmerking toe
  3. SteelSeries Nimbus+ Triggers Replacement, Unscrew the back cover: stap 3, afbeelding 1 van 1
    • Use a Y1 Tri-point screwdriver to remove the five 9.1 mm-long screws securing the back cover.
    Vraag FixBot
    Voeg opmerking toe
  4. SteelSeries Nimbus+ Triggers Replacement, Insert an opening pick: stap 4, afbeelding 1 van 2 SteelSeries Nimbus+ Triggers Replacement, Insert an opening pick: stap 4, afbeelding 2 van 2
    • The back cover is held in place by plastic clips.
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the right controller handle.
    Vraag FixBot
    Voeg opmerking toe
  5. SteelSeries Nimbus+ Triggers Replacement, Release the plastic clips: stap 5, afbeelding 1 van 2 SteelSeries Nimbus+ Triggers Replacement, Release the plastic clips: stap 5, afbeelding 2 van 2
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the right edge.
    Vraag FixBot
    Voeg opmerking toe
  6. SteelSeries Nimbus+ Triggers Replacement, Insert an opening pick: stap 6, afbeelding 1 van 2 SteelSeries Nimbus+ Triggers Replacement, Insert an opening pick: stap 6, afbeelding 2 van 2
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the left controller handle.
    Vraag FixBot
    Voeg opmerking toe
  7. SteelSeries Nimbus+ Triggers Replacement, Release the plastic clips: stap 7, afbeelding 1 van 2 SteelSeries Nimbus+ Triggers Replacement, Release the plastic clips: stap 7, afbeelding 2 van 2
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the left edge.
    Vraag FixBot
    Voeg opmerking toe
  8. SteelSeries Nimbus+ Triggers Replacement, Unfold the back cover assembly: stap 8, afbeelding 1 van 3 SteelSeries Nimbus+ Triggers Replacement, Unfold the back cover assembly: stap 8, afbeelding 2 van 3 SteelSeries Nimbus+ Triggers Replacement, Unfold the back cover assembly: stap 8, afbeelding 3 van 3
    • Carefully fold the back cover assembly to the top of the SteelSeries Nimbus+ and bring it in an 90 degree angle.
    • Do not try to remove the back cover assembly all the way yet! It is still connected to mainboard.
    Vraag FixBot
    Voeg opmerking toe
  9. SteelSeries Nimbus+ Triggers Replacement, Disconnect the battery cable: stap 9, afbeelding 1 van 3 SteelSeries Nimbus+ Triggers Replacement, Disconnect the battery cable: stap 9, afbeelding 2 van 3 SteelSeries Nimbus+ Triggers Replacement, Disconnect the battery cable: stap 9, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Use a pair of blunt nose tweezers to disconnect the battery cable from the mainboard.
    Vraag FixBot
    Voeg opmerking toe
  10. SteelSeries Nimbus+ Triggers Replacement, Remove the back cover assembly: stap 10, afbeelding 1 van 1
    • Remove the back cover assembly.
    Vraag FixBot
    Voeg opmerking toe
  11. SteelSeries Nimbus+ Triggers Replacement, Unscrew the board: stap 11, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the two 7.0 mm-long screws securing the board.
    Vraag FixBot
    Voeg opmerking toe
  12. SteelSeries Nimbus+ Triggers Replacement, Disconnect the thumbstick board: stap 12, afbeelding 1 van 3 SteelSeries Nimbus+ Triggers Replacement, Disconnect the thumbstick board: stap 12, afbeelding 2 van 3 SteelSeries Nimbus+ Triggers Replacement, Disconnect the thumbstick board: stap 12, afbeelding 3 van 3
    • Disconnect the thumbstick board by pulling it straight out its socket on the mainboard.
    Vraag FixBot
    Voeg opmerking toe
  13. SteelSeries Nimbus+ Triggers Replacement, Remove the board: stap 13, afbeelding 1 van 1
    • Remove the board with the thumbsticks from the mainboard.
    Vraag FixBot
    Voeg opmerking toe
  14. SteelSeries Nimbus+ Triggers Replacement, Unscrew the mainboard: stap 14, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the five 7.0 mm-long screws securing the mainboard to the front assembly.
    Vraag FixBot
    Voeg opmerking toe
  15. SteelSeries Nimbus+ Triggers Replacement, Lift up the mainboard: stap 15, afbeelding 1 van 3 SteelSeries Nimbus+ Triggers Replacement, Lift up the mainboard: stap 15, afbeelding 2 van 3 SteelSeries Nimbus+ Triggers Replacement, Lift up the mainboard: stap 15, afbeelding 3 van 3
    • Use your fingers to lift up the mainboard from the front case.
    • Remove the mainboard.
    Vraag FixBot
    Voeg opmerking toe
  16. SteelSeries Nimbus+ Triggers Replacement, Unscrew the triggers: stap 16, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the four 7.0 mm screws securing the triggers on the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  17. SteelSeries Nimbus+ Triggers Replacement, Release the right trigger: stap 17, afbeelding 1 van 2 SteelSeries Nimbus+ Triggers Replacement, Release the right trigger: stap 17, afbeelding 2 van 2
    • Pull the right trigger straight out to slide it off of the rails securing it to the button connector on the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  18. SteelSeries Nimbus+ Triggers Replacement, Release the left trigger: stap 18, afbeelding 1 van 2 SteelSeries Nimbus+ Triggers Replacement, Release the left trigger: stap 18, afbeelding 2 van 2
    • Pull the left trigger straight out to slide it off of the rails securing it to the button connector on the motherboard.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Adriana Zwink
67.744 Reputatie
167 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
31.437 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 21
Altijd: 649
