Ga door naar hoofdinhoud
Steam Machine Inkterface Assembly Guide
Wat je nodig hebt
Video overzicht
    1. Steam Machine Inkterface Assembly Guide, Attaching your boards to your plate: stap 1, afbeelding 1 van 3 Steam Machine Inkterface Assembly Guide, Attaching your boards to your plate: stap 1, afbeelding 2 van 3 Steam Machine Inkterface Assembly Guide, Attaching your boards to your plate: stap 1, afbeelding 3 van 3
      • Position your breakout board with the connector on the underside and facing towards the opening on the left-hand side of the Board Plate.
      • Position your Feather module of choice with the USB-C connector on the underside and facing the opening on the right-hand side of the Board Plate.
      • Once you have your boards positioned, secure your boards to the plate with 4 M2.6 x 5mm Machine Screws.
      • Be sure to tighten the screws gently to avoid cracking, or damaging, the Board Plate.
      Vraag FixBot
      Voeg opmerking toe
    2. Steam Machine Inkterface Assembly Guide, Wiring your boards together: stap 2, afbeelding 1 van 3 Steam Machine Inkterface Assembly Guide, Wiring your boards together: stap 2, afbeelding 2 van 3 Steam Machine Inkterface Assembly Guide, Wiring your boards together: stap 2, afbeelding 3 van 3
      • Using 30 AWG wire with solicone insulation, solder your connections to your board according to the wiring diagrams shown above.
      • If you are using Feather Board V1, use the first wiring diagram.
      • If you are using Feather Board V2, use the second wiring diagram.
      • Be sure to keep your wires as short, and as direct as possible. Once your connections are soldered, your board should look something like the third image.
      Vraag FixBot
      Voeg opmerking toe
    3. Steam Machine Inkterface Assembly Guide, Assemble your Faceplate and Midplate: stap 3, afbeelding 1 van 3 Steam Machine Inkterface Assembly Guide, Assemble your Faceplate and Midplate: stap 3, afbeelding 2 van 3 Steam Machine Inkterface Assembly Guide, Assemble your Faceplate and Midplate: stap 3, afbeelding 3 van 3
      • Remove the protective film from the eInk panel and place the panel in the matching recess in the faceplate.
      • Their is a cutout at the bottom of the faceplate for the eInk panel's ribbon cable. When you insert your panel it should rest in this cutout.
      • Once your eInk display is placed in the faceplate, drop in your left and right Midplates and insert your 4 K&J SB443-OUT magnets into the four slots in the midplates.
      • Depending on what your print settings you may need to press the magnets in forcibly. Ideally you would want to print at a tolerence of around .10 mm to .15mm.
      Vraag FixBot
      Voeg opmerking toe
    4. Steam Machine Inkterface Assembly Guide, Mounting the Board Plate over your Midplate: stap 4, afbeelding 1 van 2 Steam Machine Inkterface Assembly Guide, Mounting the Board Plate over your Midplate: stap 4, afbeelding 2 van 2
      • Carefully position your Board Plate so that the wires connecting your eInk Breakout board and your Feather board fit into the channel between the Mid Plates
      • Make sure that the wiring isn't being pinched between your Board Plate and Mid Plates.
      • Mount your board plate using 8 M2.5 x 5mm screws.
      • Gently tighen your screws to avoid cracking or damaging any of the 3D printed parts.
      Vraag FixBot
      Voeg opmerking toe
    5. Steam Machine Inkterface Assembly Guide, Mounting the battery and battery retainer: stap 5, afbeelding 1 van 3 Steam Machine Inkterface Assembly Guide, Mounting the battery and battery retainer: stap 5, afbeelding 2 van 3 Steam Machine Inkterface Assembly Guide, Mounting the battery and battery retainer: stap 5, afbeelding 3 van 3
      • Carefully route your battery cable under the board plate and up next to the battery connector on the Feather Board.
      • Do not connect the battery just yet.
      • Place your battery in the cutout created by the Board and Mid Plates.
      • Place the Battery Retainer over your battery and fix it in place with your last M2.5 x 5 mm screw.
      Vraag FixBot
      Voeg opmerking toe
    6. Steam Machine Inkterface Assembly Guide, Connecting your breakout board and battery: stap 6, afbeelding 1 van 2 Steam Machine Inkterface Assembly Guide, Connecting your breakout board and battery: stap 6, afbeelding 2 van 2
      • Carefully unlatch the Lock Tab Connector on your breakout board and feed the flex cable into the connector, and lock it into place with the tab.
      • Only a small amount of the copper pads on the cable should be visible. The ribbon cable should be properly locked into place when their are no gaps on either side of the locking tab.
      • Carefully connect your battery to your Feather Board. The LEDs on the board should light up.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Congradulations! The assembly of your Inkerface is now complete! The last thing you will need to do is flash Valve's custom firmware to the Feather Board. Valve has made the firmware publicly available on their Gitlab page, and Valve highly recommends using PlatformIO and running the following commands to install the firmware...
cd ./firmware
If you have a _V1_ feather: pio run -e featherv1 -t upload
Or if you have a _V2_ feather: pio run -e featherv2 -t upload
Regardless of the board you’re using, you’ll need to physically connect it via USB and grant permission to interact with serial devices on your system.
Jacob Mehnert
49.554 Reputatie
52 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 27
Afgelopen 7 dagen: 200
Afgelopen 30 dagen: 208
Altijd: 208
