Ga door naar hoofdinhoud
Spy Net Ultra Vision Goggles Microphone Replacement
Wat je nodig hebt
    1. Spy Net Ultra Vision Goggles Microphone Replacement, Open the Device: stap 1, afbeelding 1 van 1
      • Using the screwdriver, remove the six silver 11.4 mm Phillips #0 screws that hold the device shell in place.
      • Pull apart the back of the device, using the plastic opening tool if needed. To do this, locate the groves running along the side of the entire device and wedge it open.
      Vraag FixBot
      Voeg opmerking toe
    2. Spy Net Ultra Vision Goggles Microphone Replacement, Un-Solder the Wiring from the Circuit Board: stap 2, afbeelding 1 van 1
      • Find the connection of the red and black wires to the circuit board behind the LED screen.
      • Un-solder the wires from the board using the soldering iron.
      • Need Help Soldering? Check out Hoe moet je (de-)solderen?
      Vraag FixBot
      Voeg opmerking toe
    3. Spy Net Ultra Vision Goggles Microphone Replacement, Un-Solder the Microphone: stap 3, afbeelding 1 van 1
      • Find the connection of the red and black wires to the funnel-shaped lens cover.
      • Un-solder the wires from the microphone using the soldering iron.
      • Remove the red and black wires from the device and solder on the replacement.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Justin Diehl
66 Reputatie
1 Handleiding geschreven
USF Tampa, Team 4-5, Brown Fall 2014 Lid van USF Tampa, Team 4-5, Brown Fall 2014
USFT-BROWN-F14S4G5
3 Leden
42 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 33
Altijd: 673
