Ga door naar hoofdinhoud
Spy Net Ultra Vision Goggles Infrared Lights Replacement
Wat je nodig hebt
  1. Spy Net Ultra Vision Goggles Infrared Lights Replacement, Open the Device: stap 1, afbeelding 1 van 1
    • Remove the six silver 11.4 mm Phillips #0 screws that hold the device shell in place.
    • Pry open the shell using the plastic opening tools if necessary. To do this, locate the groves running along the side of the entire device and wedge it open.
    Vraag FixBot
    Voeg opmerking toe
  2. Spy Net Ultra Vision Goggles Infrared Lights Replacement, Remove the Infrared Lights: stap 2, afbeelding 1 van 3 Spy Net Ultra Vision Goggles Infrared Lights Replacement, Remove the Infrared Lights: stap 2, afbeelding 2 van 3 Spy Net Ultra Vision Goggles Infrared Lights Replacement, Remove the Infrared Lights: stap 2, afbeelding 3 van 3
    • Find the infrared light assemblies, which are located at the front end of the device on either side of the lens.
    • The process is the same regardless of which light you are replacing.
    • Lift the light assembly away from the rest of the device.
    Vraag FixBot
    Voeg opmerking toe
  3. Spy Net Ultra Vision Goggles Infrared Lights Replacement, Open the Light Assembly: stap 3, afbeelding 1 van 1
    • Use the plastic opening tools to pry open the light assembly.
    Vraag FixBot
    Voeg opmerking toe
  4. Spy Net Ultra Vision Goggles Infrared Lights Replacement, Disconnect the Lights: stap 4, afbeelding 1 van 1
    • Use the soldering iron and desoldering braid to de-solder the wires from the lights.
    • Check out This Guide for tips on soldering and de-soldering connections.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Travis Kempf
198 Reputatie
1 Handleiding geschreven
USF Tampa, Team 4-5, Brown Fall 2014 Lid van USF Tampa, Team 4-5, Brown Fall 2014
USFT-BROWN-F14S4G5
3 Leden
12 handleidingen geschreven
1Gids Commentaar
thanks for the help
vincentarriesgado - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 36
Altijd: 1,359
