Ga door naar hoofdinhoud
Sony TCM-450 Belt (Counter) Replacement
Wat je nodig hebt
  1. Sony TCM-450 Belt (Counter) Replacement, Back Cabinet: stap 1, afbeelding 1 van 3 Sony TCM-450 Belt (Counter) Replacement, Back Cabinet: stap 1, afbeelding 2 van 3 Sony TCM-450 Belt (Counter) Replacement, Back Cabinet: stap 1, afbeelding 3 van 3
    • Remove the two 3.5 mm Phillips #00 screws from the bottom of the device.
    • Caution: Ensure the device is off and unplugged if using the power adapter, as it is unsafe to remove the cabinet while on and will cause damage and potential harm to the user.
  2. Sony TCM-450 Belt (Counter) Replacement: stap 2, afbeelding 1 van 3 Sony TCM-450 Belt (Counter) Replacement: stap 2, afbeelding 2 van 3 Sony TCM-450 Belt (Counter) Replacement: stap 2, afbeelding 3 van 3
    • Open the lid, and carefully remove the two 9.7 mm Phillips #0 screws from the inside of the front cabinet.
    • Exercise caution while removing these screws, as damage to essential parts may occur and other minor damages may occur if the screwdriver slips.
  3. Sony TCM-450 Belt (Counter) Replacement: stap 3, afbeelding 1 van 3 Sony TCM-450 Belt (Counter) Replacement: stap 3, afbeelding 2 van 3 Sony TCM-450 Belt (Counter) Replacement: stap 3, afbeelding 3 van 3
    • Open the battery cover, and gently remove the back cabinet with the iFixit Opening tool.
    • The device will make a popping sound when removing the back cabinet. The back cabinet may feel as if it is not loose. However, as long as the back cabinet looks disconnected from the lid, it is safe to remove.
  4. Sony TCM-450 Belt (Counter) Replacement, PCB/Motherboard/Circuit Board: stap 4, afbeelding 1 van 2 Sony TCM-450 Belt (Counter) Replacement, PCB/Motherboard/Circuit Board: stap 4, afbeelding 2 van 2
    • Carefully desolder each connection and gently remove each connected wire.
    • If you are unfamiliar with desoldering and soldering, please consult the iFixit Soldering Guide.
    • Make sure the soldering iron is 50 watts as 30-40 watt soldering irons will not melt the solder on the PCB.
  5. Sony TCM-450 Belt (Counter) Replacement: stap 5, afbeelding 1 van 2 Sony TCM-450 Belt (Counter) Replacement: stap 5, afbeelding 2 van 2
    • Carefully desolder the next set of connections and gently remove the connected wires.
  6. Sony TCM-450 Belt (Counter) Replacement: stap 6, afbeelding 1 van 2 Sony TCM-450 Belt (Counter) Replacement: stap 6, afbeelding 2 van 2
    • Carefully desolder the last two groups of connections and gently remove the wires.
    • Caution: Desolder all three marked connections at once before attempting to remove the wires, as they will not fully disconnect and cause damage to the device.
  7. Sony TCM-450 Belt (Counter) Replacement: stap 7, afbeelding 1 van 3 Sony TCM-450 Belt (Counter) Replacement: stap 7, afbeelding 2 van 3 Sony TCM-450 Belt (Counter) Replacement: stap 7, afbeelding 3 van 3
    • Carefully remove the three inner screws as shown from the circuit board to loosen it.
    • Remove the following screws in this order:
    • A 3.4 mm Phillips #00
    • A 4.6 mm Phillips #00
    • A 9.7 mm Phillips #0. To remove this screw you must lift the PCB at the same time.
  8. Sony TCM-450 Belt (Counter) Replacement: stap 8, afbeelding 1 van 1
    • Lift the PCB from the device.
    • Make sure not to pull out any wires while lifting the board, as it could cause damage to the device.
  9. Sony TCM-450 Belt (Counter) Replacement, Belt for Counter: stap 9, afbeelding 1 van 2 Sony TCM-450 Belt (Counter) Replacement, Belt for Counter: stap 9, afbeelding 2 van 2
    • Remove the counter belt by pulling it gently out and away from the parts it connects to and away from the board.
    • Make sure that you do not pull the belt too hard, or it may snap back and hit you as it is made of rubber.
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Brayden Sneed
467 Reputatie
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 6
Altijd: 52
