Ga door naar hoofdinhoud
Sony Cyber-shot DSC-W290 Flash Bulb Replacement
William Schill
William Schill en 5 andere bijdragers
Voor het laatst geüpdatet op December 15, 2020
30 minuten
Moeilijk
Make sure you have all of the requisite tools on hand before beginning to replace the flash bulb.
Wat je nodig hebt
Gereedschap
Toon meer…
  1. Sony Cyber-shot DSC-W290 Flash Bulb Replacement, Battery: stap 1, afbeelding 1 van 1
    • Find the hatch labeled "open" on the left side of the bottom of the camera.
    • Slide the hatch in the direction that the arrow is pointing. The hatch will open outward on its own.
  2. Sony Cyber-shot DSC-W290 Flash Bulb Replacement: stap 2, afbeelding 1 van 1
    • Slide the blue locking tab to release the battery.
    • Slide the battery out of the camera.
  3. Sony Cyber-shot DSC-W290 Flash Bulb Replacement, Outer Casing: stap 3, afbeelding 1 van 2 Sony Cyber-shot DSC-W290 Flash Bulb Replacement, Outer Casing: stap 3, afbeelding 2 van 2
    • Replace hatch and rotate camera 180 degrees. You should still be looking at the bottom of the camera.
    • Remove the four 2.5mm Phillips #0 screws.
  4. Sony Cyber-shot DSC-W290 Flash Bulb Replacement: stap 4, afbeelding 1 van 3 Sony Cyber-shot DSC-W290 Flash Bulb Replacement: stap 4, afbeelding 2 van 3 Sony Cyber-shot DSC-W290 Flash Bulb Replacement: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Turn the camera so the left side-panel reading "5x Optical Zoom" faces you.
    • Remove the two 2.5mm Phillips #0 screws.
    • You may have to remove the screws with a pair of tweezers when the screws are almost out.
  5. Sony Cyber-shot DSC-W290 Flash Bulb Replacement: stap 5, afbeelding 1 van 3 Sony Cyber-shot DSC-W290 Flash Bulb Replacement: stap 5, afbeelding 2 van 3 Sony Cyber-shot DSC-W290 Flash Bulb Replacement: stap 5, afbeelding 3 van 3
    • Turn the camera so the right side faces you.
  6. Sony Cyber-shot DSC-W290 Flash Bulb Replacement: stap 6, afbeelding 1 van 1
    • Rotate camera so that the back is facing you.
    • Pull the back casing directly away from the LCD screen.
  7. Sony Cyber-shot DSC-W290 Flash Bulb Replacement: stap 7, afbeelding 1 van 2 Sony Cyber-shot DSC-W290 Flash Bulb Replacement: stap 7, afbeelding 2 van 2
    • Turn the camera so that the left side is facing you.
    • Pull the left side-panel off of the camera.
  8. Sony Cyber-shot DSC-W290 Flash Bulb Replacement: stap 8, afbeelding 1 van 2 Sony Cyber-shot DSC-W290 Flash Bulb Replacement: stap 8, afbeelding 2 van 2
    • Turn camera so that the front of the camera is facing you.
    • Pull the front casing directly away from the camera.
    • The right side panel may fall off when you take the front panel off.
  9. Sony Cyber-shot DSC-W290 Flash Bulb Replacement: stap 9, afbeelding 1 van 2 Sony Cyber-shot DSC-W290 Flash Bulb Replacement: stap 9, afbeelding 2 van 2
    • Turn the camera so that the right side is facing you.
    • Pull the right side-panel away from the rest of the camera.
  10. Sony Cyber-shot DSC-W290 Flash Bulb Replacement: stap 10, afbeelding 1 van 2 Sony Cyber-shot DSC-W290 Flash Bulb Replacement: stap 10, afbeelding 2 van 2
    • This is what your camera should look like now that you have removed the casing from all sides.
  11. Sony Cyber-shot DSC-W290 Flash Bulb Replacement, LCD Assembly: stap 11, afbeelding 1 van 1
    • Gently pull the LCD and its casing away from the motherboard as shown.
    • Be careful not to rip out any ribbon cables.
  12. Sony Cyber-shot DSC-W290 Flash Bulb Replacement: stap 12, afbeelding 1 van 2 Sony Cyber-shot DSC-W290 Flash Bulb Replacement: stap 12, afbeelding 2 van 2
    • Disconnect the small ribbon-wire by gently pulling on the small ribbon-wire where it connects with the motherboard.
    • Do not use excessive force to remove the wire because this may cause it to tear.
  13. Sony Cyber-shot DSC-W290 Flash Bulb Replacement: stap 13, afbeelding 1 van 2 Sony Cyber-shot DSC-W290 Flash Bulb Replacement: stap 13, afbeelding 2 van 2
    • Disconnect the large ribbon-wire by pulling on the large ribbon-wire where it connects to the motherboard.
  14. Sony Cyber-shot DSC-W290 Flash Bulb Replacement: stap 14, afbeelding 1 van 1
    • Pull the LCD and its casing away from the rest of the camera.
  15. Sony Cyber-shot DSC-W290 Flash Bulb Replacement, Flash Bulb Assembly: stap 15, afbeelding 1 van 2 Sony Cyber-shot DSC-W290 Flash Bulb Replacement, Flash Bulb Assembly: stap 15, afbeelding 2 van 2
    • Turn the camera so the back is facing you.
    • Remove the 2.5mm Philips #0 screw at the top of the camera.
  16. Sony Cyber-shot DSC-W290 Flash Bulb Replacement: stap 16, afbeelding 1 van 3 Sony Cyber-shot DSC-W290 Flash Bulb Replacement: stap 16, afbeelding 2 van 3 Sony Cyber-shot DSC-W290 Flash Bulb Replacement: stap 16, afbeelding 3 van 3
    • Tilt top casing up and towards you.
    • Carefully remove the right ribbon-wire from the top camera panel by pulling where the wire connects to the top.
    • Make sure to hold the camera with your thumb on the white square to ensure the ribbon-wire is not disconnected from the motherboard.
    • Carefully remove the left ribbon-wire from the top camera panel by pulling where the wire connects to the top.
  17. Sony Cyber-shot DSC-W290 Flash Bulb Replacement, Flash Bulb: stap 17, afbeelding 1 van 3 Sony Cyber-shot DSC-W290 Flash Bulb Replacement, Flash Bulb: stap 17, afbeelding 2 van 3 Sony Cyber-shot DSC-W290 Flash Bulb Replacement, Flash Bulb: stap 17, afbeelding 3 van 3
    • Pull the top of the camera off and turn it so the bottom is facing you.
    • Desolder the three connections from the bulb to the small circuit board.
    • Remove the excess solder using your soldering iron and desoldering wick.
  18. Sony Cyber-shot DSC-W290 Flash Bulb Replacement: stap 18, afbeelding 1 van 2 Sony Cyber-shot DSC-W290 Flash Bulb Replacement: stap 18, afbeelding 2 van 2
    • Gently wiggle the flash bulb to remove it from the joints.
    • It may be necessary to use the soldering iron to heat up the joints as you pull it off.
Conclusie
William Schill
225 Reputatie
3 handleidingen geschreven
Cal Poly, Team 7-54, Amido Fall 2010 Lid van Cal Poly, Team 7-54, Amido Fall 2010
CPSU-AMIDO-F10S7G54
4 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 26
Altijd: 7,090
