Ga door naar hoofdinhoud
Sony Cyber-shot DSC-HX1 Lens Assembly Replacement
Brianna Greenlaw
Brianna Greenlaw en een andere bijdrager
Voor het laatst geüpdatet op January 14, 2021
40 - 45 minuten
Moeilijk
To take out and replace the lens assembly, you must first completely remove the central motherboard and all other internal components.
Wat je nodig hebt
Gereedschap
  1. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure the surface you place the screen on is clean of debris and dust. Otherwise you risk scratching your screen.
    • Place the camera with the bottom facing you and the lens facing up.
  2. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: stap 2, afbeelding 1 van 1
    • Push down and away from the camera to the left on the indicated indentation in the battery cover. The compartment should slide open as shown.
  3. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: stap 3, afbeelding 1 van 2 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: stap 3, afbeelding 2 van 2
    • Push the blue tab towards the camera body to the right, while simultaneously pulling out the battery.
    • The battery is not shown here. However, normally the battery would be in the displayed compartment.
  4. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement, Motherboard: stap 4, afbeelding 1 van 2 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement, Motherboard: stap 4, afbeelding 2 van 2
    • Close the battery cover by pushing the cover inwards and sliding it to the left to allow more maneuverability when disassembling other parts of the camera.
  5. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: stap 5, afbeelding 1 van 1
    • Unscrew the four #00 4.0 mm Phillips screws on the bottom of the camera.
  6. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: stap 6, afbeelding 1 van 1
    • Remove the two #00 4.0 mm Phillips screws shown on the side of the camera.
  7. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: stap 7, afbeelding 1 van 1
    • Unscrew the #00 4.0 mm Phillips screw on the top next to the view finder.
  8. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: stap 8, afbeelding 1 van 1
    • Pull open the plastic port covers on the side of the camera.
    • Remove the revealed #00 4.0 mm Phillips screw.
  9. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: stap 9, afbeelding 1 van 3 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: stap 9, afbeelding 2 van 3 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: stap 9, afbeelding 3 van 3
    • Lift the back LCD screen to reveal the back of the camera unit.
    • Unscrew the three #00 4.0 mm Phillips screws at the edge and center of the back camera unit.
  10. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: stap 10, afbeelding 1 van 3 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: stap 10, afbeelding 2 van 3 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: stap 10, afbeelding 3 van 3
    • Using the plastic opening tool, pry apart the bottom of the camera at the line between the four removed screws.
    • Place the camera on its lens and use the plastic opening tool to pry at the crack in the case on all four sides of the camera.
    • Apply moderate force to the backside of the camera enclosure until the two pieces separate.
  11. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: stap 11, afbeelding 1 van 2 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: stap 11, afbeelding 2 van 2
    • Remove the #00 4.0 mm Phillips screw and the #00 6.0 mm Phillips screw holding the motherboard to the front enclosure.
    • Disconnect the eight ribbon cables from their ports on the motherboard.
  12. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: stap 12, afbeelding 1 van 2 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: stap 12, afbeelding 2 van 2
    • Detach the metal bracket from the enclosure by removing the two #00 4.0 mm Phillips screws.
  13. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: stap 13, afbeelding 1 van 2 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: stap 13, afbeelding 2 van 2
    • If you feel resistance from the board, double check all screws and cables have been removed to avoid damage.
    • Completely remove the motherboard by gently pulling the board away from the camera.
  14. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement, Lens Assembly: stap 14, afbeelding 1 van 1
    • Unscrew the #00 6.0 mm Phillips screw on the left side of the lens.
  15. Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: stap 15, afbeelding 1 van 2 Sony Cyber-shot DSC-HX1 Lens Assembly Replacement: stap 15, afbeelding 2 van 2
    • The lens assembly contains exposed leads to capacitors. Be very careful to avoid contact or discharge capacitors before handling as touching the capacitors could lead to electric shock.
    • Gently slide the lens assembly out of the front camera housing and remove completely.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Brianna Greenlaw
1.217 Reputatie
5 handleidingen geschreven
Cal Poly, Team 17-3, Forte Spring 2015 Lid van Cal Poly, Team 17-3, Forte Spring 2015
CPSU-FORTE-S15S17G3
4 Leden
10 handleidingen geschreven
2 opmerkingen
Hi!
Very good tutorial, thanks a lot.
I have a question : after reassembling the device, do you need to do some kind of adjustment or is it "simply plug-and-play"?
Best regards,
Marin
Marin Aymon - Antwoord
Muy bueno el tutorial felicitaciones, sin embargo faltaron tornillos por nombrar, saludos
Cesar Carrillo - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 72
Altijd: 5,759
