Ga door naar hoofdinhoud
Sony Cyber-shot DSC-HX1 LCD Screen Replacement
Brianna Greenlaw
Brianna Greenlaw en 2 andere bijdragers
Voor het laatst geüpdatet op January 13, 2021
10 - 15 minuten
Gemiddeld
Replacement of this component will involve the disassembly of the screen's enclosure and careful disconnection of its cable.
Wat je nodig hebt
Gereedschap
  1. Sony Cyber-shot DSC-HX1 LCD Screen Replacement, LCD Screen: stap 1, afbeelding 1 van 1
    • Extend the LCD screen away from the camera to access the screws on the back of its housing.
  2. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: stap 2, afbeelding 1 van 1
    • Unscrew the three #00 2.0 mm Phillips screws on the back of the casing.
  3. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: stap 3, afbeelding 1 van 1
    • Place the camera with the lens down.
    • Tilt the screen upwards to see the screw on the bottom of the housing.
    • Unscrew this #00 4.0 mm Phillips screw.
  4. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: stap 4, afbeelding 1 van 1
    • Pry the casing apart using your plastic opening tool. Begin by prying at the hole where you removed the screw and continue along the seam.
  5. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: stap 5, afbeelding 1 van 2 Sony Cyber-shot DSC-HX1 LCD Screen Replacement: stap 5, afbeelding 2 van 2
    • Lift the transparent section of the plastic housing off.
    • Lift the rubber screen bumper off of the screen.
  6. Sony Cyber-shot DSC-HX1 LCD Screen Replacement: stap 6, afbeelding 1 van 1
    • Pull up on the screen to reveal the data attachment cable.
    • Carefully pull the LCD screen away from enclosure to remove the cable and screen completely.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Brianna Greenlaw
1.217 Reputatie
5 handleidingen geschreven
Cal Poly, Team 17-3, Forte Spring 2015 Lid van Cal Poly, Team 17-3, Forte Spring 2015
CPSU-FORTE-S15S17G3
4 Leden
10 handleidingen geschreven
5 opmerkingen
What is the lcd screen part number? And where can i find it online? I need to replace my dads cracked screen.
sportyvangchick - Antwoord
lao90227ay
s300gc05lb9e21xmo usp5280371
lajos rohony - Antwoord
Screen LCDOnline booking
prince Choudhary - Antwoord
qual tela de lcd posso usar?
não achei
Thayane Laurencio - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 48
Altijd: 3,515
