Ga door naar hoofdinhoud
Scuf Instinct Pro Bumpers Replacement
Wat je nodig hebt
  1. Scuf Instinct Pro Bumpers Replacement, Prepare your controller for disassembly: stap 1, afbeelding 1 van 2 Scuf Instinct Pro Bumpers Replacement, Prepare your controller for disassembly: stap 1, afbeelding 2 van 2
    • Unplug all cables from your controller before starting.
    • Completely power off your controller.
    • Due to the controller’s odd shape, it can be helpful to stabilize it as you work. To prevent damage, consider laying it on a soft surface like a cloth or towel.
  2. Scuf Instinct Pro Bumpers Replacement, Remove the faceplate: stap 2, afbeelding 1 van 3 Scuf Instinct Pro Bumpers Replacement, Remove the faceplate: stap 2, afbeelding 2 van 3 Scuf Instinct Pro Bumpers Replacement, Remove the faceplate: stap 2, afbeelding 3 van 3
    • Magnets secure the faceplace to the midframe.
    • Lift the top edge of the faceplate to release the magnets securing it.
    • Remove the faceplate.
  3. Scuf Instinct Pro Bumpers Replacement, Remove the battery cover: stap 3, afbeelding 1 van 2 Scuf Instinct Pro Bumpers Replacement, Remove the battery cover: stap 3, afbeelding 2 van 2
    • Weak magnets and two clips along the bottom edge secure the battery cover to the controller.
    • Slide the battery cover away from the controller to remove it.
  4. Scuf Instinct Pro Bumpers Replacement, Remove the batteries: stap 4, afbeelding 1 van 3 Scuf Instinct Pro Bumpers Replacement, Remove the batteries: stap 4, afbeelding 2 van 3 Scuf Instinct Pro Bumpers Replacement, Remove the batteries: stap 4, afbeelding 3 van 3
    • If your batteries are starting to corrode, clean the contacts and replace the batteries.
    • Use your fingers to remove the batteries.
    • During reassembly, insert the batteries so their positive (+) and negative () ends match up with the markings on the battery contacts.
  5. Scuf Instinct Pro Bumpers Replacement, Heat the battery sticker: stap 5, afbeelding 1 van 2 Scuf Instinct Pro Bumpers Replacement, Heat the battery sticker: stap 5, afbeelding 2 van 2
    • The sticker in the battery recess hides a back cover screw.
    • If you don't care about damaging the sticker, you can puncture through the center and skip the next step.
    • Use a hair dryer to heat the sticker and soften the adhesive securing it.
    • The sticker can be peeled without heating, but you risk tearing it.
  6. Scuf Instinct Pro Bumpers Replacement, Peel up the battery sticker: stap 6, afbeelding 1 van 3 Scuf Instinct Pro Bumpers Replacement, Peel up the battery sticker: stap 6, afbeelding 2 van 3 Scuf Instinct Pro Bumpers Replacement, Peel up the battery sticker: stap 6, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Use the point of a spudger to push up a corner of the sticker until you can grab it with a pair of blunt nose tweezers.
    • Use your tweezers to peel up the sticker until the back cover screw is accessible.
  7. Scuf Instinct Pro Bumpers Replacement, Unfasten the midframe: stap 7, afbeelding 1 van 3 Scuf Instinct Pro Bumpers Replacement, Unfasten the midframe: stap 7, afbeelding 2 van 3 Scuf Instinct Pro Bumpers Replacement, Unfasten the midframe: stap 7, afbeelding 3 van 3
    FixMat
    $36.95
    Koop
    • Use a T8 Torx screwdriver to remove five 9.3 mm‑long screws securing the midframe:
    • One back cover screw
    • Four screws on top of the midframe
    • Use a T6 Torx screwdriver to remove the two 9.3 mm‑long screws securing the midframe.
  8. Scuf Instinct Pro Bumpers Replacement, Unclip the midframe: stap 8, afbeelding 1 van 3 Scuf Instinct Pro Bumpers Replacement, Unclip the midframe: stap 8, afbeelding 2 van 3 Scuf Instinct Pro Bumpers Replacement, Unclip the midframe: stap 8, afbeelding 3 van 3
    • Plastic clips secure the bottom edge of the midframe.
    • Insert the flat end of a spudger between the bottom edge of the midframe and back cover.
    • Pry the midframe up with the spudger to release the clips.
    • Continue prying along the bottom edge to release the remaining clips.
    • Don't try to remove the midframe from the back cover yet—a delicate ribbon cable connects them.
  9. Scuf Instinct Pro Bumpers Replacement, Prop up the midframe: stap 9, afbeelding 1 van 3 Scuf Instinct Pro Bumpers Replacement, Prop up the midframe: stap 9, afbeelding 2 van 3 Scuf Instinct Pro Bumpers Replacement, Prop up the midframe: stap 9, afbeelding 3 van 3
    • Put a box or a stack of books to the right of the controller so you can prop up the midframe while disconnecting its ribbon cable.
    • Secure the back cover with one hand, and use your other hand to grip the midframe's left edge.
    • Lift the midframe and rotate it over the right edge of the back cover, so the midframe's right edge is on your workspace.
    • Prop the midframe up, being careful not to strain the ribbon cable.
  10. Scuf Instinct Pro Bumpers Replacement, Reassembly information: stap 10, afbeelding 1 van 3 Scuf Instinct Pro Bumpers Replacement, Reassembly information: stap 10, afbeelding 2 van 3 Scuf Instinct Pro Bumpers Replacement, Reassembly information: stap 10, afbeelding 3 van 3
    • During reassembly:
    • Guide the battery connectors on the midframe through their slot in the back cover.
    • Make sure the contacts slide into their grooves in the battery recess. If they aren't in the correct spot, the controller won't receive power.
  11. Scuf Instinct Pro Bumpers Replacement, Disconnect the midframe: stap 11, afbeelding 1 van 3 Scuf Instinct Pro Bumpers Replacement, Disconnect the midframe: stap 11, afbeelding 2 van 3 Scuf Instinct Pro Bumpers Replacement, Disconnect the midframe: stap 11, afbeelding 3 van 3
    Koop
    • A very small rubber grommet secures the midframe's ribbon cable to a post on the right side of the back cover.
    • Use blunt nose tweezers to remove the grommet—don't lose it!
  12. Scuf Instinct Pro Bumpers Replacement: stap 12, afbeelding 1 van 2 Scuf Instinct Pro Bumpers Replacement: stap 12, afbeelding 2 van 2
    • Use the flat end of a spudger or a clean fingernail to lift the hinged locking flap on the midframe cable ZIF connector.
  13. Scuf Instinct Pro Bumpers Replacement: stap 13, afbeelding 1 van 3 Scuf Instinct Pro Bumpers Replacement: stap 13, afbeelding 2 van 3 Scuf Instinct Pro Bumpers Replacement: stap 13, afbeelding 3 van 3
    • Use blunt nose tweezers to grip the black pull tab on the midframe cable.
    • Lift the midframe cable off its post and pull it straight out of its socket.
  14. Scuf Instinct Pro Bumpers Replacement, Remove the midframe: stap 14, afbeelding 1 van 1
    • Remove the midframe.
  15. Scuf Instinct Pro Bumpers Replacement, Remove the USB‑C port cover: stap 15, afbeelding 1 van 3 Scuf Instinct Pro Bumpers Replacement, Remove the USB‑C port cover: stap 15, afbeelding 2 van 3 Scuf Instinct Pro Bumpers Replacement, Remove the USB‑C port cover: stap 15, afbeelding 3 van 3
    • The top of the USB‑C port cover is secured with a pair of plastic arms. The bottom is secured with plastic clips.
    • Rotate the underside of the USB‑C port cover up and away from the controller to release the bottom clips.
    • Unhook the plastic arms and remove the cover.
    • Hook the ends of the USB‑C cover's arms into their slots on either side of the Xbox button.
    • Rotate the cover downward until the bottom clips engage and the cover is flush with the bumpers.
  16. Scuf Instinct Pro Bumpers Replacement, Unclip a bumper: stap 16, afbeelding 1 van 3 Scuf Instinct Pro Bumpers Replacement, Unclip a bumper: stap 16, afbeelding 2 van 3 Scuf Instinct Pro Bumpers Replacement, Unclip a bumper: stap 16, afbeelding 3 van 3
    • Tight plastic clips secure the outer edges of the bumpers. Unclipping them requires some force.
    • Insert the point of a spudger between the midframe and the inner edge of one of the clips.
    • Pry the clip outward until it comes off its post and the bumper is freed.
  17. Scuf Instinct Pro Bumpers Replacement, Remove the bumpers: stap 17, afbeelding 1 van 3 Scuf Instinct Pro Bumpers Replacement, Remove the bumpers: stap 17, afbeelding 2 van 3 Scuf Instinct Pro Bumpers Replacement, Remove the bumpers: stap 17, afbeelding 3 van 3
    • Use your fingers to rotate the other bumper away from the controller until the clip comes off its post.
    • Remove the bumpers.
    • Make sure the tabs on the midframe and bumpers go into their corresponding cutouts.
    • Hook one of the bumpers onto its post and push the other bumper into the midframe until its clip snaps into place.
Conclusie
Spencer Day
59.654 Reputatie
430 handleidingen geschreven
iFixit Lid van iFixit
Staff
141 Leden
17.895 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 29
Afgelopen 30 dagen: 116
Altijd: 732
