Samsung SPH-A660 Keypad Replacement
Inleiding
Ga naar stap 1Is your keypad not working properly? There may be extra dust and dirt stuck up underneath it that is hindering its operations. To fix this problem follow these steps.
Wat je nodig hebt
Gereedschap
Once the battery pack is removed from the phone, remove the five indicated screws with a size #00 Philips screwdriver.
Bend back the antenna to access the indicated left middle screw in order to unscrew it.
Remove the keypad from the body by grasping the white rubbery pad and lifting it off the phone.
