Inleiding
This guide will cover the removal of the Samsung SCH-U340 top casing.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Turn the cell phone so that the back side is facing you. Press the upper indent and slide the back cover down.
The outer casing consists of two separate parts on the upper and lower halves of the device. The upper outer casing is held on through a combination of screws and tabs. First remove the plastic plugs covering the screws with a spudger.
Één andere persoon heeft deze handleiding voltooid.
