Samsung Rogue Speaker/Antenna Replacement
Inleiding
Ga naar stap 1This guide will provide a step-by-step procedure for replacing the antenna and speaker in your Samsung Rogue.
Wat je nodig hebt
Gereedschap
With your thumbs, push down on the back cover of your phone and slide it away from the camera.
Use a plastic opening tool to carefully pry the back cover surrounding the camera up from the phone.
On the underside of the motherboard, remove the single 3.3mm Philips screw.
