Ga door naar hoofdinhoud
Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement
Wat je nodig hebt
  1. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Unplug your refrigerator: stap 1, afbeelding 1 van 1
    • Unplug your refrigerator before you begin your repair.
  2. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Open the freezer drawer: stap 2, afbeelding 1 van 2 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Open the freezer drawer: stap 2, afbeelding 2 van 2
    • Slide the freezer drawer fully open.
  3. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the freezer bins: stap 3, afbeelding 1 van 3 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the freezer bins: stap 3, afbeelding 2 van 3 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the freezer bins: stap 3, afbeelding 3 van 3
    • Lift and remove all the freezer bins from the drawer.
    • You may need to open the refrigerator doors in order to remove the large bin.
  4. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the freezer door: stap 4, afbeelding 1 van 3 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the freezer door: stap 4, afbeelding 2 van 3 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the freezer door: stap 4, afbeelding 3 van 3
    • A plastic tab locks each drawer rail in place.
    • Use a flathead screwdriver or your fingers to press in the plastic tab near the inner end of the drawer rail.
    • While pressing the plastic tab, grasp the rail with your free hand and slide it towards you slightly to unlock the rail.
  5. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: stap 5, afbeelding 1 van 1
    • Repeat the rail unlock procedure on the other drawer rail.
  6. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: stap 6, afbeelding 1 van 1
    • Once both rails are unlocked, firmly pull both rails to slide them out of the refrigerator wall guides.
    • Remove the freezer drawer.
    • To reinstall the freezer drawer:
    • Push the geared torsion bar until it rests at the very end of the rails.
    • Align the drawer rails to the refrigerator wall guides.
    • Close the freezer drawer until the rails lock back in place.
    • If you don't hear a click, visually check if the plastic tabs have locked in place. You may need to push the rails in a little further with your fingers to set the tabs.
  7. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the evaporator cover: stap 7, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the two 18.5 mm‑long screws securing the evaporator cover to the refrigerator.
  8. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: stap 8, afbeelding 1 van 2 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: stap 8, afbeelding 2 van 2
    • Lift the bottom edge of the evaporator cover away from the refrigerator to release the bottom clips.
    • Don't try to fully remove the cover. It's still connected by a few wires.
    • Shift the evaporator cover downwards to access the connectors in the top right corner of the freezer compartment.
  9. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Disconnect the fan connector: stap 9, afbeelding 1 van 3 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Disconnect the fan connector: stap 9, afbeelding 2 van 3 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Disconnect the fan connector: stap 9, afbeelding 3 van 3
    • Squeeze the bottom edge of the fan connector to unlock it from the freezer wall.
    • Pull and disconnect the fan connector.
  10. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the evaporator cover: stap 10, afbeelding 1 van 1
    • Remove the evaporator cover.
  11. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Loosen the fan cable: stap 11, afbeelding 1 van 3 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Loosen the fan cable: stap 11, afbeelding 2 van 3 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Loosen the fan cable: stap 11, afbeelding 3 van 3
    • Guide the fan cable out of the evaporator cover clips.
    • If you have trouble getting the cable out of the clips, squeeze the clips with pliers to create a wider gap.
  12. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the evaporator back panel: stap 12, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the five 14.5 mm‑long screws securing the back panel to the evaporator cover.
  13. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: stap 13, afbeelding 1 van 3 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: stap 13, afbeelding 2 van 3 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: stap 13, afbeelding 3 van 3
    • Use your fingers to pry and release the clips along the short edge of the evaporator cover.
    • If the perimeter foam insulation prevents you from releasing the clips, cut the foam with scissors.
  14. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: stap 14, afbeelding 1 van 3 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: stap 14, afbeelding 2 van 3 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: stap 14, afbeelding 3 van 3
    • Lift and separate the back panel from the evaporator cover.
  15. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement, Remove the evaporator fan: stap 15, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the three 14.2 mm‑long screws securing the evaporator fan.
  16. Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: stap 16, afbeelding 1 van 2 Samsung RF28T5001SR Refrigerator Evaporator Fan Replacement: stap 16, afbeelding 2 van 2
    • Lift and remove the evaporator fan.
    • During reassembly, be sure to install the fan in the right orientation: the side with the center label should face down towards the evaporator cover.
Conclusie
Arthur Shi
258.910 Reputatie
531 handleidingen geschreven
iFixit Lid van iFixit
Staff
140 Leden
18.077 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 46
Afgelopen 30 dagen: 183
Altijd: 1,356
