Inleiding
Back panel removal is required when reaching RAM, HDD, Optic Drive, Wi-Fi Card, Cooling fan/Heatsink and CPU. This guide will display the steps needed to remove the back panel.
Wat je nodig hebt
Using the Phillips #0 screwdriver, unscrew the one 5mm screw.
Using the blue plastic opening tools, wedge one in between the back panel and the laptop.
Carefully remove the back panel..
Bijna klaar!
Conclusie
