Samsung Gear Fit Battery Replacement
Inleiding
Ga naar stap 1Getting to the battery requires disassembling the entire device, but the battery itself is easy to remove.
Wat je nodig hebt
Onderdelen
Gereedschap
Toon meer…
Place your thumbs on the ends of the screen.
Push the watch outward while pulling the band away from the watch.
Use a hair dryer, heat gun, or an iOpener to heat the Gear Fit for 1-2 minutes until it is hot to the touch.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Three ribbon cables hold the motherboard to the rest of the assembly.
The battery cable in the front.
And two on the side.
Using a pair of tweezers, carefully pull each connector away to disconnect it from the rest of the assembly.
With the motherboard removed, the battery is exposed.
A small metal strut protects the battery.
Remove the small metal strut by prying it out of both sides of the enclosure.
To reassemble your device, follow these instructions in reverse order. Make sure that the ribbon cable connecting the battery is firmly attached; Don't be afraid to use some force.
37 andere personen hebben deze handleiding voltooid.
10 opmerkingen
Bgdhdhdhxhzjxjchf
Gdkysgkdgkdgxgmzg
Anyone know where I can find replacement parts for the charging terminals? One of the 5 fell out and I can't seem to find this simple piece anywhere.
Where i can purchase a replacement battery in india?
