Ga door naar hoofdinhoud
Samsung Gear 2 Neo Battery Replacement
Victor Yore
Victor Yore en 6 andere bijdragers
Voor het laatst geüpdatet op May 7, 2024
10 minuten
Eenvoudig
After prolonged use, the battery may not hold as long of a charge as it did initially. In this case, the battery will need to be replaced. Do not worry, because battery replacement on the Samsung Gear 2 Neo is one of the easier repairs to complete.
Wat je nodig hebt
Gereedschap
Toon meer…
  1. Samsung Gear 2 Neo Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the wristband by sliding the metal pins located on both sides of the wrist band, and pulling the wristband off.
  2. Samsung Gear 2 Neo Battery Replacement: stap 2, afbeelding 1 van 2 Samsung Gear 2 Neo Battery Replacement: stap 2, afbeelding 2 van 2
    • Use a T5 Torx Screwdriver to remove the 4 (0.4 mm) screws located on the back of the watch.
  3. Samsung Gear 2 Neo Battery Replacement: stap 3, afbeelding 1 van 1
    • Slide the opening tool in between the two halves of the case and slide along the edge of the watch while gently prying the back cover away from the face of the watch.
  4. Samsung Gear 2 Neo Battery Replacement: stap 4, afbeelding 1 van 2 Samsung Gear 2 Neo Battery Replacement: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use a pair of tweezers to peel the battery ribbon cable off of the back cover.
    • Avoid damaging the gold terminals on the ribbon cable.
    • When reassembling, make sure that the yellow strip snaps back on to the black pin.
    • The pin is located, and marked on the picture.
    • Pull up on the tab that says, “Pull”, the battery will lift straight out.
Conclusie
10 andere personen hebben deze handleiding voltooid.
Victor Yore
705 Reputatie
5 handleidingen geschreven
USF Tampa, Team 5-6, Blackwell Fall 2015 Lid van USF Tampa, Team 5-6, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G6
3 Leden
7Gids Commentaar
How so I change or repair the gold terminals
Prez - Antwoord
How do I repair or replace gold terminals
Prez - Antwoord
Did you ever find out how to repair those can I have the same problem ?
Brya -
I’m not sure why the comment was lost in my inbox. To answer the question regard the gold charging pins, the ones visible in step 2 for the first picture, you’d have to slide a pair of tweezers underneath the blue chip the one seen in step 4. this is dangerous as it’s more integrated to the case than the other parts. At that point you’d need to find a replacement pin set. I haven’t personally worked with the watch for sometime as i no longer have it due to the fact it needed to be returned. In other words this is only a best guess from my experience working with the watch. You might need to unhook the gold tab underneath the blue chip to give yourself a little extra room.
Adam Jeranek - Antwoord
If my gear 2. Neo is being inside water and switching on the display is blurry sounds are working but I cannot see a digital screen what should I do to fix it
Arjun Singh Rathod - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 25
Altijd: 6,855
