Samsung Galaxy S4 Motherboard Replacement
Inleiding
Ga naar stap 1Use this guide to replace the motherboard in your Samsung Galaxy S4.
Wat je nodig hebt
Onderdelen
Gereedschap
Toon meer…
Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
After the click, release the card and it will pop out of its slot.
Remove the microSD card.
Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
Remove the battery from your phone.
Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
Remove the SIM card.
Remove the nine 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
Use the flat end of a spudger to disconnect the USB board connector.
Disconnect the front-facing camera cable connector.
Disconnect the earpiece speaker assembly cable connector.
Use the flat end of a spudger to disconnect the rear-facing camera connector.
159 andere personen hebben deze handleiding voltooid.
30 opmerkingen
I have a M919 with dead motherboard. Can i swap with an i9505motherboard insted? will all the components work on this new motherboard?
Hi I have a question. I have Galaxy S4 but The screen just broke and my sister give her galaxy s4 can i just change the motherboard to my phone or need to change the other parts too? Please help my i dont want to change all the parts if i dont need to!?
Mboard only.
i need S4 mother board too broher pls give me if you have extra i will pay
