Ga door naar hoofdinhoud
Samsung Galaxy S20+ Screen and Battery Assembly Replacement
Wat je nodig hebt
  1. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Eject the SIM tray: stap 1, afbeelding 1 van 2 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Eject the SIM tray: stap 1, afbeelding 2 van 2
    • Insert a SIM card eject tool, bit, or a straightened paperclip into the hole on the SIM tray, located at the top edge of the phone next to the plastic antenna band.
    • If you inserted the tool into the other hole, don't worry—the microphone and the ingress gasket are mounted out of harm's way.
    • Press in firmly to eject the tray.
  2. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Remove the SIM tray: stap 2, afbeelding 1 van 2 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Remove the SIM tray: stap 2, afbeelding 2 van 2
    • Remove the SIM card tray.
    • The SIM card will fall out of the tray easily.
    • When you reinsert the SIM card, ensure that it is in the proper orientation relative to the tray.
    • A thin rubber gasket around the SIM tray provides water and dust protection. If this gasket is damaged or missing, replace the gasket or the entire SIM tray to protect your phone's internal components.
  3. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Heat the bottom edge: stap 3, afbeelding 1 van 1
    • Unplug and power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's bottom edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  4. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Separate the bottom edge adhesive: stap 4, afbeelding 1 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Separate the bottom edge adhesive: stap 4, afbeelding 2 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Separate the bottom edge adhesive: stap 4, afbeelding 3 van 3
    • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken glass.
    • Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Insert the point of an opening pick into the gap.
    • Due to tight tolerances, this may take multiple attempts of reheating with the iOpener and separating with the suction cup before you get it right.
    • If you are having trouble creating a gap, apply more heat to the edge and try again.
    • Do not apply excessive force with the pick, or you risk cracking the back cover glass.
  5. Samsung Galaxy S20+ Screen and Battery Assembly Replacement: stap 5, afbeelding 1 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement: stap 5, afbeelding 2 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement: stap 5, afbeelding 3 van 3
    • Slide the pick back and forth along the bottom edge to slice through the adhesive.
    • Do not attempt to cut the adhesive near the corners of the phone where the glass is curved or you risk cracking the glass panel.
    • Leave your opening pick in the seam to prevent the adhesive from resealing.
  6. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Heat the left edge: stap 6, afbeelding 1 van 1
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  7. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Separate the left edge adhesive: stap 7, afbeelding 1 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Separate the left edge adhesive: stap 7, afbeelding 2 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Separate the left edge adhesive: stap 7, afbeelding 3 van 3
    • Apply a suction cup to the back of the phone, as close to the center of the left edge as possible.
    • As the glass on this edge is curved, you won't be able to insert this pick very far. As long as the very tip of the pick is underneath the glass's edge, you will be able to proceed.
    • Due to tight tolerances, this may take multiple attempts.
    • You can try also applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
  8. Samsung Galaxy S20+ Screen and Battery Assembly Replacement: stap 8, afbeelding 1 van 2 Samsung Galaxy S20+ Screen and Battery Assembly Replacement: stap 8, afbeelding 2 van 2
    • Once the pick is underneath the glass's edge, tilt it downward and insert it further to fully separate the back cover's adhesive.
  9. Samsung Galaxy S20+ Screen and Battery Assembly Replacement: stap 9, afbeelding 1 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement: stap 9, afbeelding 2 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement: stap 9, afbeelding 3 van 3
    • Slide the pick all along the left edge of the phone to separate the back cover's adhesive.
    • Take care when sliding across the ridge in the frame surrounding the volume and power buttons—the cutout in the glass may make it more prone to cracking.
    • Leave your pick under the left edge of the glass to prevent the adhesive from resealing.
  10. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Heat the right edge: stap 10, afbeelding 1 van 1
    • Apply a heated iOpener to the right edge of the back cover for two minutes.
  11. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Separate the right edge adhesive: stap 11, afbeelding 1 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Separate the right edge adhesive: stap 11, afbeelding 2 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Separate the right edge adhesive: stap 11, afbeelding 3 van 3
    • Apply a suction cup to the back of the phone, as close to the center of the right edge as possible.
    • Like with the previous edge, you will need to tilt the opening pick downward to fully insert it underneath the back cover.
  12. Samsung Galaxy S20+ Screen and Battery Assembly Replacement: stap 12, afbeelding 1 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement: stap 12, afbeelding 2 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement: stap 12, afbeelding 3 van 3
    • Slide the pick all along the right edge of the phone to separate the back cover's adhesive.
    • Leave your pick under the right edge of the glass near the top of the device to prevent the adhesive from resealing.
    • As you do this, the back cover may release one or both of the other picks and allow them to fall free. If this occurs, set the pick(s) aside as the bottom edge shouldn't reseal from this point onward.
  13. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Heat the top edge: stap 13, afbeelding 1 van 1
    • Apply a heated iOpener to the top edge of the back cover for two minutes.
  14. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Separate the top edge adhesive: stap 14, afbeelding 1 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Separate the top edge adhesive: stap 14, afbeelding 2 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Separate the top edge adhesive: stap 14, afbeelding 3 van 3
    • The glass near the corners of the back cover is curved and very susceptible to cracking. Be gentle during this step to prevent damaging your back cover.
    • Gradually slide the pick from the right edge of the device around the top right corner.
    • Continue slicing along the top edge all the way around to the left edge to fully separate the back cover adhesive.
    • If the slicing becomes difficult at any point, stop and reapply heat before continuing.
  15. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Remove the back cover: stap 15, afbeelding 1 van 2 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Remove the back cover: stap 15, afbeelding 2 van 2
    • Lift the back cover slowly. Use opening picks to slice any remaining adhesive.
    • Remove the back cover.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
    • If you're using Samsung custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  16. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Unfasten the motherboard bracket: stap 16, afbeelding 1 van 2 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Unfasten the motherboard bracket: stap 16, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Magnetic Project Mat
    $19.95
    Koop
    • Use a Phillips #00 screwdriver to remove the six 4 mm-long screws securing the motherboard bracket.
    • If you're reassembling with the Samsung Self-Repair kit, be sure to replace the screws with new ones labeled #3373.
  17. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Unclip the motherboard bracket: stap 17, afbeelding 1 van 2 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Unclip the motherboard bracket: stap 17, afbeelding 2 van 2
    • Use a pair of tweezers to gently pull up and unclip the motherboard bracket from the plastic midframe.
    • Do not completely remove the bracket yet, as its still attached to the wireless charging coil.
  18. Samsung Galaxy S20+ Screen and Battery Assembly Replacement: stap 18, afbeelding 1 van 2 Samsung Galaxy S20+ Screen and Battery Assembly Replacement: stap 18, afbeelding 2 van 2
    • Gently tilt up the motherboard bracket so the orange battery connector is accessible.
  19. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Disconnect the battery: stap 19, afbeelding 1 van 2 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Disconnect the battery: stap 19, afbeelding 2 van 2
    • Use a spudger to pry up and disconnect the battery connector.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
  20. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Disconnect the wireless charging coil: stap 20, afbeelding 1 van 2 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Disconnect the wireless charging coil: stap 20, afbeelding 2 van 2
    • Use a spudger to pry up and disconnect the wireless charging coil connector.
  21. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Unfasten the loudspeaker: stap 21, afbeelding 1 van 2 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Unfasten the loudspeaker: stap 21, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the five 4 mm-long screws securing the loudspeaker and lower midframe.
  22. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Disconnect the loudspeaker: stap 22, afbeelding 1 van 2 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Disconnect the loudspeaker: stap 22, afbeelding 2 van 2
    • Insert the point of a spudger into the notch in the top left corner of the midframe and pry up to release the clips holding it in place.
    • Remove the loudspeaker and lower midframe.
  23. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Remove the wireless charging coil: stap 23, afbeelding 1 van 2 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Remove the wireless charging coil: stap 23, afbeelding 2 van 2
    • Use a pair of blunt-nose tweezers to gently peel the wireless charging coil away from the device.
    • Remove the wireless charging coil.
    • During reassembly, first reconnect the charging coil and battery connectors and refasten the motherboard bracket screws to properly align everything into place, then firmly press the coil pad down to adhere it.
  24. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Disconnect the daughterboard: stap 24, afbeelding 1 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Disconnect the daughterboard: stap 24, afbeelding 2 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Disconnect the daughterboard: stap 24, afbeelding 3 van 3
    • Use a spudger to pry up and disconnect the primary and secondary flex cables from the daughterboard near the bottom of the device.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  25. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Disconnect the main flex cables: stap 25, afbeelding 1 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Disconnect the main flex cables: stap 25, afbeelding 2 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Disconnect the main flex cables: stap 25, afbeelding 3 van 3
    • Use a spudger to pry up and disconnect the primary and secondary flex cables from the motherboard.
  26. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Remove the flex cables: stap 26, afbeelding 1 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Remove the flex cables: stap 26, afbeelding 2 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Remove the flex cables: stap 26, afbeelding 3 van 3
    • Gently peel up and remove the primary and secondary flex cables.
  27. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Unfasten the daughterboard: stap 27, afbeelding 1 van 2 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Unfasten the daughterboard: stap 27, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the three 3.4 mm-long screws securing the USB-C port and daughterboard.
  28. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Remove the daughterboard: stap 28, afbeelding 1 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Remove the daughterboard: stap 28, afbeelding 2 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Remove the daughterboard: stap 28, afbeelding 3 van 3
    • Insert the pointed end of a spudger under the left edge of the daughterboard and pry up to release it from its recess.
    • Use a pair of blunt-nose tweezers to pull the daughterboard up and away from the bottom of the device and remove it.
  29. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Heat the vibrator: stap 29, afbeelding 1 van 1
    • Apply a heated iOpener to the bottom-right corner of the device for 90 seconds.
  30. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Remove the vibrator: stap 30, afbeelding 1 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Remove the vibrator: stap 30, afbeelding 2 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Remove the vibrator: stap 30, afbeelding 3 van 3
    • Insert the tip of a spudger between the frame and the notch in the vibrator's edge, close to the bottom edge of the device.
    • Pry up with the spudger to separate the vibrator from the frame.
    • Remove the vibrator.
    • Set the vibrator aside. You'll reuse it during reassembly.
  31. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Vibrator reassembly instructions: stap 31, afbeelding 1 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Vibrator reassembly instructions: stap 31, afbeelding 2 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Vibrator reassembly instructions: stap 31, afbeelding 3 van 3
    • During reassembly, follow these instructions to reinstall your vibrator:
    • Peel off the vibrator adhesive from its liner and apply the sticky end to the bottom of the vibrator.
    • Use tweezers, or your fingers, to pull up on the white liner to expose the top layer of adhesive.
    • Insert the vibrator and apply pressure to adhere it to the frame.
    • The adhesive is very thin and hard to distinguish from the liner. Use your fingers to check if the adhesive transferred correctly.
  32. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Disconnect the left 5G mmWave antenna: stap 32, afbeelding 1 van 2 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Disconnect the left 5G mmWave antenna: stap 32, afbeelding 2 van 2
    • Pry up and disconnect the left 5G mmWave antenna cable from the motherboard.
  33. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Disconnect the main display cable: stap 33, afbeelding 1 van 2 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Disconnect the main display cable: stap 33, afbeelding 2 van 2
    • Use a spudger to pry up and disconnect the main display flex cable from the motherboard.
  34. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Reposition the cables: stap 34, afbeelding 1 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Reposition the cables: stap 34, afbeelding 2 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Reposition the cables: stap 34, afbeelding 3 van 3
    • Gently peel up and bend the display and left 5G mmWave antenna flex cables out of the way of the motherboard and battery.
  35. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Unfasten the upper midframe: stap 35, afbeelding 1 van 2 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Unfasten the upper midframe: stap 35, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the three 4 mm-long screws securing the upper midframe.
  36. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Remove the upper midframe: stap 36, afbeelding 1 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Remove the upper midframe: stap 36, afbeelding 2 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Remove the upper midframe: stap 36, afbeelding 3 van 3
    • Insert the point of a spudger into the notch on the right side of the upper midframe and pry up to release the clips holding it into place.
    • Remove the upper midframe.
    • Set the upper midframe aside. You'll reuse it during reassembly.
  37. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Disconnect the right 5G mmWave antenna: stap 37, afbeelding 1 van 2 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Disconnect the right 5G mmWave antenna: stap 37, afbeelding 2 van 2
    • Use a spudger to pry up and disconnect the right 5G mmWave antenna flex cable from the motherboard.
    • Bend the cable out of the way of the motherboard.
  38. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Disconnect the side button cable: stap 38, afbeelding 1 van 2 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Disconnect the side button cable: stap 38, afbeelding 2 van 2
    • Pry up and disconnect the side button flex cable from the motherboard.
  39. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Disconnect the front facing camera: stap 39, afbeelding 1 van 2 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Disconnect the front facing camera: stap 39, afbeelding 2 van 2
    • Pry up and disconnect the front facing camera flex cable from the motherboard.
  40. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Remove the upper 5G mmWave antenna: stap 40, afbeelding 1 van 2 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Remove the upper 5G mmWave antenna: stap 40, afbeelding 2 van 2
    • Use the flat end of a spudger to pry up and disconnect the 5G mmWave antenna module.
    • Use the flat end of a spudger to pry up the corner of the antenna module.
    • The module is secured with a bit of adhesive, but should release easily.
    • Remove the mmWave antenna module.
    • During reassembly, reconnect the antenna connector first to properly align it into place, then firmly press the rest of the module down to adhere it.
  41. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Unfasten the motherboard assembly: stap 41, afbeelding 1 van 2 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Unfasten the motherboard assembly: stap 41, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the two screws securing the motherboard and camera assembly:
    • One 4 mm-long screw
    • One 3.4 mm-long screw
    • If you're reassembling with the Samsung Self-Repair kit, be sure to replace the screws with new ones:
    • Screw labelled #3373
    • Screw labelled #3394
  42. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Remove the motherboard assembly: stap 42, afbeelding 1 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Remove the motherboard assembly: stap 42, afbeelding 2 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Remove the motherboard assembly: stap 42, afbeelding 3 van 3
    • Insert the flat end of a spudger into the bottom left corner of the motherboard assembly and pry up to release it from the phone body.
    • Remove the motherboard assembly.
  43. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Heat the front camera: stap 43, afbeelding 1 van 1
    • Apply a heated iOpener to the front camera for 90 seconds.
  44. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Remove the front camera: stap 44, afbeelding 1 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Remove the front camera: stap 44, afbeelding 2 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Remove the front camera: stap 44, afbeelding 3 van 3
    • Insert a spudger into the gap between the frame and the front camera.
    • Pry up with the spudger to separate the front camera from the frame.
    • If you're having trouble separating the front camera from the frame, apply more heat.
    • Use tweezers, or your fingers, to remove the front camera.
    • Set the camera aside. You'll reuse it during reassembly.
  45. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Front camera reassembly instructions: stap 45, afbeelding 1 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Front camera reassembly instructions: stap 45, afbeelding 2 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Front camera reassembly instructions: stap 45, afbeelding 3 van 3
    • During reassembly, follow these instructions to reinstall your front camera:
    • Peel off the front camera adhesive from its liner and apply the sticky end to the frame.
    • Use tweezers, or your fingers, to pull on the tab and expose the top layer of adhesive.
    • Insert the front camera and apply pressure to adhere it to the frame.
  46. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Unfasten the 5G mmWave antennas: stap 46, afbeelding 1 van 2 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Unfasten the 5G mmWave antennas: stap 46, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the four 3.4 mm-long screws securing the 5G mmWave antennas.
    • If you're reassembling with the Samsung Self-Repair kit, be sure to replace the screws with new ones labeled #3394.
  47. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Remove the right 5G antenna: stap 47, afbeelding 1 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Remove the right 5G antenna: stap 47, afbeelding 2 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Remove the right 5G antenna: stap 47, afbeelding 3 van 3
    • Use the point of a spudger to pry up on the 5G antenna bracket's bottom screw tab.
    • Use tweezers, or your fingers, to remove the 5G antenna.
  48. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Remove the left 5G antenna: stap 48, afbeelding 1 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Remove the left 5G antenna: stap 48, afbeelding 2 van 3 Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Remove the left 5G antenna: stap 48, afbeelding 3 van 3
    • Use the point of a spudger to pry up on the 5G antenna bracket's top edge.
  49. Samsung Galaxy S20+ Screen and Battery Assembly Replacement, Only the screen and battery assembly remains: stap 49, afbeelding 1 van 1
    • You're now left with the screen and battery assembly.
Conclusie
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
After you've completed the repair, download the Samsung Members App from the Galaxy Store or the Play Store, and Samsung Self-Repair document (beginning page 10) to make sure your device is fully functional.
Download the Self Repair Assistant on your device and follow the Samsung Self-Repair document (beginning page 11) to perform a battery cycle reset.
13 andere personen hebben deze handleiding voltooid.
Alex Diaz-Kokaisl
119.442 Reputatie
549 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.817 handleidingen geschreven
4 opmerkingen
I just finished this repair. Note that when separating the back cover, you can go straight in for the top and bottom. The sides have curves in the glass. This requires angling your tool slightly up towards back cover to separate. Too much could scratch the back glass.
Also, between step 23 and #0024 there is a missing step. Before you heat and remove the vibrate component, you need to remove the circuit board for the charging port. There are 3 screws to remove using the #00 Phillips screwdriver. Also, disconnect the two ribbons. You can just disconnect the Main side to remove them with the circuit board.
Finally, I have yet to be able to find the Galaxy Cal APK
Dave Long - Antwoord
Hi Dave.
Thank you for the comment! I have added the missing steps. To find the Galaxy Cal APK, there's a link in the conclusion section labeled "Galaxy Cal App" that should give you the APK.
Alex Diaz-Kokaisl -
I really appreciate the response and the link. I downloaded and when I tried to run, after install, the app received the message "Try again after getting new version." The apk was Version 1.0.1-usa. Can you please advise? Thanks.
Dave Long -
This requires an immense amount of patience and the persistent use of heat to disassemble this phone. I ended up breaking the front camera module while trying to pry it loose. Fortunately, this is available as a repair part and I was able to replace the front screen, camera, and battery and the phone now works perfectly.
Rusty Teer - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 10
Afgelopen 7 dagen: 86
Afgelopen 30 dagen: 390
Altijd: 10,521
