Ga door naar hoofdinhoud
Samsung Galaxy Note9 Front Sensor Array Replacement
Wat je nodig hebt
  1. Samsung Galaxy Note9 Front Sensor Array Replacement, Eject the SIM card tray: stap 1, afbeelding 1 van 2 Samsung Galaxy Note9 Front Sensor Array Replacement, Eject the SIM card tray: stap 1, afbeelding 2 van 2
    • Insert a SIM card eject tool straight into the hole in the SIM card tray.
    • Press to eject the SIM card tray.
    Vraag FixBot
    Voeg opmerking toe
  2. Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the SIM card tray: stap 2, afbeelding 1 van 1
    • Remove the SIM card tray.
    • The SIM card will fall out of the tray easily.
    Vraag FixBot
    Voeg opmerking toe
  3. Samsung Galaxy Note9 Front Sensor Array Replacement, Apply a heated iOpener: stap 3, afbeelding 1 van 1
    • Power off your phone before beginning disassembly.
    • Use a hairdryer, a heatgun, or prepare an iOpener and apply it to the right edge of the back of the phone for about a minute to soften the adhesive underneath.
    Vraag FixBot
    Voeg opmerking toe
  4. Samsung Galaxy Note9 Front Sensor Array Replacement, Insert an opening pick: stap 4, afbeelding 1 van 3 Samsung Galaxy Note9 Front Sensor Array Replacement, Insert an opening pick: stap 4, afbeelding 2 van 3 Samsung Galaxy Note9 Front Sensor Array Replacement, Insert an opening pick: stap 4, afbeelding 3 van 3
    • Apply a suction handle to the back cover.
    • Lift with a suction handle to create a gap between the back cover and the frame of the phone.
    • Insert an opening pick into the gap.
    • If the glass is badly cracked, cover it in packing tape to create a surface for the suction cup to adhere to.
    • If the adhesive won't budge, apply more heat, not excessive force. Too much force could break the glass.
    Vraag FixBot
    Voeg opmerking toe
  5. Samsung Galaxy Note9 Front Sensor Array Replacement, Cut through the adhesive: stap 5, afbeelding 1 van 1
    • Note that there is more adhesive along the top edge and around the camera bezel than around the rest of the phone.
    • Cut carefully around the left edge near the fingerprint sensor or you risk damaging the ribbon cable inside.
    • If, at any point, the adhesive feels stubborn, apply more heat—not more force.
    Vraag FixBot
    Voeg opmerking toe
  6. Samsung Galaxy Note9 Front Sensor Array Replacement, Slide the opening pick: stap 6, afbeelding 1 van 3 Samsung Galaxy Note9 Front Sensor Array Replacement, Slide the opening pick: stap 6, afbeelding 2 van 3 Samsung Galaxy Note9 Front Sensor Array Replacement, Slide the opening pick: stap 6, afbeelding 3 van 3
    • Starting from the center, cut the adhesive up and down the right side with an opening pick.
    • Do not insert the pick more than halfway into the phone when cutting near the fingerprint sensor or cameras, or you risk damaging internal components.
    Vraag FixBot
    Voeg opmerking toe
  7. Samsung Galaxy Note9 Front Sensor Array Replacement: stap 7, afbeelding 1 van 3 Samsung Galaxy Note9 Front Sensor Array Replacement: stap 7, afbeelding 2 van 3 Samsung Galaxy Note9 Front Sensor Array Replacement: stap 7, afbeelding 3 van 3
    • Be careful near the corner, as the glass is very weak. Apply more heat at any time if the adhesive becomes stuck.
    • Leave an opening pick in the upper-right corner.
    • Use another opening pick to cut the adhesive around the bottom-right corner.
    • Leave that opening pick in the phone.
    Vraag FixBot
    Voeg opmerking toe
  8. Samsung Galaxy Note9 Front Sensor Array Replacement: stap 8, afbeelding 1 van 1
    • Use a heat gun or hair dryer or apply a heated iOpener to the left side of the rear panel for at three minutes to soften the adhesive underneath.
    Vraag FixBot
    Voeg opmerking toe
  9. Samsung Galaxy Note9 Front Sensor Array Replacement: stap 9, afbeelding 1 van 3 Samsung Galaxy Note9 Front Sensor Array Replacement: stap 9, afbeelding 2 van 3 Samsung Galaxy Note9 Front Sensor Array Replacement: stap 9, afbeelding 3 van 3
    • Be careful near the corners, as the glass is weakest there.
    • Insert an opening pick into the lower-left corner of the rear panel.
    • Using another opening pick, cut the adhesive along the left edge of the rear panel.
    • Don't insert an opening pick in more than halfway on the left edge near the fingerprint sensor or you may damage the ribbon cable inside.
    • It is fine if opening picks fall out as the back cover becomes separated.
    Vraag FixBot
    Voeg opmerking toe
  10. Samsung Galaxy Note9 Front Sensor Array Replacement: stap 10, afbeelding 1 van 3 Samsung Galaxy Note9 Front Sensor Array Replacement: stap 10, afbeelding 2 van 3 Samsung Galaxy Note9 Front Sensor Array Replacement: stap 10, afbeelding 3 van 3
    • Using the inserted opening pick, carefully cut the adhesive around the upper-left corner of the rear panel.
    • Finally, cut the last of the adhesive along the top of the phone.
    • Use an iOpener, hair dryer, or heat gun to apply more heat as needed where you are cutting the adhesive.
    Vraag FixBot
    Voeg opmerking toe
  11. Samsung Galaxy Note9 Front Sensor Array Replacement: stap 11, afbeelding 1 van 2 Samsung Galaxy Note9 Front Sensor Array Replacement: stap 11, afbeelding 2 van 2
    • Separate the right side of the rear cover first.
    • Tilt the cover up along the left edge to expose the fingerprint sensor ribbon cable.
    • Do not pull out the fingerprint sensor ribbon cable yet.
    • The fingerprint sensor cover might stay attached to the midframe.
    Vraag FixBot
    Voeg opmerking toe
  12. Samsung Galaxy Note9 Front Sensor Array Replacement, Disconnect the fingerprint sensor: stap 12, afbeelding 1 van 2 Samsung Galaxy Note9 Front Sensor Array Replacement, Disconnect the fingerprint sensor: stap 12, afbeelding 2 van 2
    • Use the tip of a spudger to pry the fingerprint sensor ribbon cable up and out of its socket.
    Vraag FixBot
    Voeg opmerking toe
  13. Samsung Galaxy Note9 Front Sensor Array Replacement: stap 13, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Remove the back cover.
    • To re-install the back cover:
    • Use tweezers to peel away any remaining adhesive from the phone's chassis. Then clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth to prep the surface for the new adhesive. You don't have to clear out adhesive down to the plastic but larger pieces should be removed.
    • Turn on your phone and test your repair before installing new adhesive and resealing the phone.
    • Carefully apply the new adhesive to the back cover, then line up one edge of the glass against the phone chassis and firmly press the glass into the phone.
    Vraag FixBot
    Voeg opmerking toe
  14. Voorzichtig: stappen 14-17 komen van een handleiding die in bewerking is.
    Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the upper midframe: stap 14, afbeelding 1 van 2 Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the upper midframe: stap 14, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the nine 4 mm screws securing the upper midframe.
    Vraag FixBot
    Voeg opmerking toe
  15. Samsung Galaxy Note9 Front Sensor Array Replacement: stap 15, afbeelding 1 van 2 Samsung Galaxy Note9 Front Sensor Array Replacement: stap 15, afbeelding 2 van 2
    • Insert the tip of a spudger into the upper-left corner of the upper midframe.
    • Pry the upper midframe out of the phone.
    • The upper midframe snaps into and out of place.
    Vraag FixBot
    Voeg opmerking toe
  16. Samsung Galaxy Note9 Front Sensor Array Replacement: stap 16, afbeelding 1 van 3 Samsung Galaxy Note9 Front Sensor Array Replacement: stap 16, afbeelding 2 van 3 Samsung Galaxy Note9 Front Sensor Array Replacement: stap 16, afbeelding 3 van 3
    • Peel the wireless charging coil off the battery starting with the left side.
    • The adhesive is weak but you can use an opening pick to cut it if necessary.
    • During reassembly start by snapping the midframe into place first before adhering the wireless charging coil.
    Vraag FixBot
    Voeg opmerking toe
  17. Samsung Galaxy Note9 Front Sensor Array Replacement, Disconnect the battery: stap 17, afbeelding 1 van 2 Samsung Galaxy Note9 Front Sensor Array Replacement, Disconnect the battery: stap 17, afbeelding 2 van 2
    • Use the tip of a spudger to disconnect the orange ribbon cable connecting the battery to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  18. Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the midframe: stap 18, afbeelding 1 van 2 Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the midframe: stap 18, afbeelding 2 van 2
    • Remove the nine 4 mm Phillips screws from the plastic cover next to the battery.
    Vraag FixBot
    Voeg opmerking toe
  19. Samsung Galaxy Note9 Front Sensor Array Replacement: stap 19, afbeelding 1 van 1
    • Remove the plastic cover next to the battery.
    Vraag FixBot
    Voeg opmerking toe
  20. Samsung Galaxy Note9 Front Sensor Array Replacement: stap 20, afbeelding 1 van 3 Samsung Galaxy Note9 Front Sensor Array Replacement: stap 20, afbeelding 2 van 3 Samsung Galaxy Note9 Front Sensor Array Replacement: stap 20, afbeelding 3 van 3
    • Insert the tip of a spudger into the top of the lower midframe.
    • Pry the lower midframe out from the phone.
    • The lower midframe snaps into and out of place.
    • Remove the lower midframe.
    Vraag FixBot
    Voeg opmerking toe
  21. Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the front camera: stap 21, afbeelding 1 van 3 Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the front camera: stap 21, afbeelding 2 van 3 Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the front camera: stap 21, afbeelding 3 van 3
    • Use the tip of a spudger to pry the front camera connector straight up and out of its socket.
    • Use tweezers to remove the front camera.
    Vraag FixBot
    Voeg opmerking toe
  22. Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the iris scanner: stap 22, afbeelding 1 van 3 Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the iris scanner: stap 22, afbeelding 2 van 3 Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the iris scanner: stap 22, afbeelding 3 van 3
    • Use the tip of a spudger to disconnect the iris scanner from the motherboard.
    • Use tweezers to remove the iris scanner.
    Vraag FixBot
    Voeg opmerking toe
  23. Samsung Galaxy Note9 Front Sensor Array Replacement, Disconnect the front sensor array: stap 23, afbeelding 1 van 2 Samsung Galaxy Note9 Front Sensor Array Replacement, Disconnect the front sensor array: stap 23, afbeelding 2 van 2
    • Use the flat end of a spudger to pry the front sensor connector out of its socket.
    Vraag FixBot
    Voeg opmerking toe
  24. Samsung Galaxy Note9 Front Sensor Array Replacement, Disconnect the display assembly: stap 24, afbeelding 1 van 2 Samsung Galaxy Note9 Front Sensor Array Replacement, Disconnect the display assembly: stap 24, afbeelding 2 van 2
    • Use the flat end of a spudger to disconnect the display cable from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  25. Samsung Galaxy Note9 Front Sensor Array Replacement: stap 25, afbeelding 1 van 2 Samsung Galaxy Note9 Front Sensor Array Replacement: stap 25, afbeelding 2 van 2
    • Use the flat end of a spudger to disconnect the touchscreen cable from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  26. Samsung Galaxy Note9 Front Sensor Array Replacement, Disconnect the charging assembly: stap 26, afbeelding 1 van 2 Samsung Galaxy Note9 Front Sensor Array Replacement, Disconnect the charging assembly: stap 26, afbeelding 2 van 2
    • Use the flat end of a spudger to disconnect the charging assembly from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  27. Samsung Galaxy Note9 Front Sensor Array Replacement: stap 27, afbeelding 1 van 2 Samsung Galaxy Note9 Front Sensor Array Replacement: stap 27, afbeelding 2 van 2
    • Remove the three 4 mm Phillips screws securing the motherboard.
    • There are triangles next to the holes indicating the motherboard screw locations.
    Vraag FixBot
    Voeg opmerking toe
  28. Samsung Galaxy Note9 Front Sensor Array Replacement: stap 28, afbeelding 1 van 3 Samsung Galaxy Note9 Front Sensor Array Replacement: stap 28, afbeelding 2 van 3 Samsung Galaxy Note9 Front Sensor Array Replacement: stap 28, afbeelding 3 van 3
    • Use a spudger to gently lift the motherbord from the upper-left corner.
    • Carefully remove the motherboard.
    • Move the ribbon cables out of the way as necessary. Do not pull the motherboard out if it becomes snagged on any cables.
    Vraag FixBot
    Voeg opmerking toe
  29. Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the front sensor array: stap 29, afbeelding 1 van 2 Samsung Galaxy Note9 Front Sensor Array Replacement, Remove the front sensor array: stap 29, afbeelding 2 van 2
    • Use a pair of tweezers to peel back the adhesive-backed copper foil.
    • Stop peeling once you reach the sensor array.
    • Be careful not to tear the foil.
    Vraag FixBot
    Voeg opmerking toe
  30. Samsung Galaxy Note9 Front Sensor Array Replacement: stap 30, afbeelding 1 van 2 Samsung Galaxy Note9 Front Sensor Array Replacement: stap 30, afbeelding 2 van 2
    • Use the tip of a spudger to lift the left side of the front sensor array and separate the adhesive the rest of the way.
    • The front sensor array is still connected to a ribbon cable that is adhered to the phone. Do not try to remove the front sensor array yet or you will damage it.
    Vraag FixBot
    Voeg opmerking toe
  31. Samsung Galaxy Note9 Front Sensor Array Replacement: stap 31, afbeelding 1 van 2 Samsung Galaxy Note9 Front Sensor Array Replacement: stap 31, afbeelding 2 van 2
    • Carefully slide an opening pick under the front sensor array ribbon cable to cut the adhesive underneath.
    Vraag FixBot
    Voeg opmerking toe
  32. Samsung Galaxy Note9 Front Sensor Array Replacement: stap 32, afbeelding 1 van 2 Samsung Galaxy Note9 Front Sensor Array Replacement: stap 32, afbeelding 2 van 2
    • Use a pair of tweezers to remove the front sensor array.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Sam Omiotek
99.599 Reputatie
290 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 48
Altijd: 1,706
