Inleiding
Use this guide to replace the USB-C port on your Samsung Galaxy Note20.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Wat je nodig hebt
Heat an iOpener and apply it to the left side of the rear cover for one minute.
Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
Insert an opening pick into the gap.
Slide the opening pick along the left edge towards the bottom left corner to cut through the adhesive.
Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
Repeat the process of heating and cutting the adhesive along the three remaining sides of the rear cover.
As you proceed, leave an opening pick in each corner to prevent the adhesive from re-sealing.
Gereedschap gebruikt in deze stap:Magnetic Project Mat$19.95
Use a Phillips screwdriver to remove the six 4.0 mm screws securing the motherboard shield.
While using a pair of tweezers to hold the motherboard shield out of the way, use the pointed end of a spudger to pry up the battery press connector.
While using a pair of tweezers to hold the motherboard shield out of the way, use the pointed end of a spudger to pry up the wireless charging coil press connector.
Grip the motherboard shield with your fingers.
Peel the wireless charging coil up and away from the device.
Remove the wireless charging coil.
Use a Phillips screwdriver to unscrew the five 4.0 mm screws securing the loudspeaker to the frame.
Use the pointed end of a spudger to disconnect the main interconnect cable from the daughterboard.
Use a Phillips screwdriver to remove the 2.9 mm screw securing the daughterboard to the frame.
Use a Phillips screwdriver to remove the two 2.9 mm screws securing the USB-C port to the phone.
Insert the pointed end of a spudger under the right side screw hole on the USB-C port.
Pry up the USB-C port to loosen it from the frame.
Grip the USB-C cable with your fingers close to the USB-C port.
Remove the USB-C port by pulling it up and away from the bottom of the phone.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy Note20 Answers community for help.
4 andere personen hebben deze handleiding voltooid.
Één opmerking
The guide is good, was going to finish the guide while replacing the battery. However the cable connected to the USB-c port was (at least for me) soldered. I had to reinstall the old port until I can get my soldering iron. Will attempt soon. Otherwise great guide.
