Ga door naar hoofdinhoud
Samsung Galaxy Note10 Motherboard Replacement
Wat je nodig hebt
  1. Samsung Galaxy Note10 Motherboard Replacement, Heat the back panel: stap 1, afbeelding 1 van 1
    • Completely power off your phone before you begin disassembly.
    • Prepare an iOpener and apply it to the left edge of the back panel for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy Note10 Motherboard Replacement, Insert an opening pick: stap 2, afbeelding 1 van 3 Samsung Galaxy Note10 Motherboard Replacement, Insert an opening pick: stap 2, afbeelding 2 van 3 Samsung Galaxy Note10 Motherboard Replacement, Insert an opening pick: stap 2, afbeelding 3 van 3
    • Apply a suction cup to the heated edge of the back panel, as close to the edge as possible.
    • If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken panel.
    • Pull up on the suction cup with strong, steady force to create a gap between the back panel and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
  3. Samsung Galaxy Note10 Motherboard Replacement, Begin to slice the adhesive: stap 3, afbeelding 1 van 3 Samsung Galaxy Note10 Motherboard Replacement, Begin to slice the adhesive: stap 3, afbeelding 2 van 3 Samsung Galaxy Note10 Motherboard Replacement, Begin to slice the adhesive: stap 3, afbeelding 3 van 3
    • Slide the opening pick along the left edge towards the bottom left corner to slice the adhesive.
    • Do not insert the opening pick more than halfway into the phone or you risk damaging internal components.
    • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
  4. Samsung Galaxy Note10 Motherboard Replacement, Slice the left side adhesive: stap 4, afbeelding 1 van 3 Samsung Galaxy Note10 Motherboard Replacement, Slice the left side adhesive: stap 4, afbeelding 2 van 3 Samsung Galaxy Note10 Motherboard Replacement, Slice the left side adhesive: stap 4, afbeelding 3 van 3
    • Insert a second opening pick and slide it across the left side towards the top left corner to slice the adhesive.
    • Leave the pick inserted in the top left corner to prevent the adhesive from re-sealing.
  5. Samsung Galaxy Note10 Motherboard Replacement, Slice the top side adhesive: stap 5, afbeelding 1 van 1
    • Prepare an iOpener and apply it to the top edge of the phone for one minute.
  6. Samsung Galaxy Note10 Motherboard Replacement: stap 6, afbeelding 1 van 3 Samsung Galaxy Note10 Motherboard Replacement: stap 6, afbeelding 2 van 3 Samsung Galaxy Note10 Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Insert a third opening pick into the gap on the top edge of the phone.
    • Slide the opening pick to the top right corner, slicing the adhesive.
    • Leave the pick inserted in the top right corner to prevent the adhesive from re-sealing.
  7. Samsung Galaxy Note10 Motherboard Replacement, Slice the right side adhesive: stap 7, afbeelding 1 van 1
    • Prepare an iOpener and apply it to the right edge of the phone for one minute.
  8. Samsung Galaxy Note10 Motherboard Replacement: stap 8, afbeelding 1 van 2 Samsung Galaxy Note10 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Insert a fourth and final opening pick into the gap on the right side of the phone, sliding it down towards the bottom right corner of the phone to slice the adhesive.
    • The back panel will begin to separate from the phone as you get closer to the bottom edge.
    • Slide an opening pick back and forth around the entire perimeter of the phone to release any missed adhesive, reheating if you find any extra-stubborn adhesive.
  9. Samsung Galaxy Note10 Motherboard Replacement, Lift off the back panel: stap 9, afbeelding 1 van 3 Samsung Galaxy Note10 Motherboard Replacement, Lift off the back panel: stap 9, afbeelding 2 van 3 Samsung Galaxy Note10 Motherboard Replacement, Lift off the back panel: stap 9, afbeelding 3 van 3
    • Lift up and remove the back panel.
  10. Samsung Galaxy Note10 Motherboard Replacement, Lift up the metal cover: stap 10, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the five 4 mm screws securing the wireless charging coil.
  11. Samsung Galaxy Note10 Motherboard Replacement: stap 11, afbeelding 1 van 3 Samsung Galaxy Note10 Motherboard Replacement: stap 11, afbeelding 2 van 3 Samsung Galaxy Note10 Motherboard Replacement: stap 11, afbeelding 3 van 3
    • Use a pair of tweezers to lift up and flip back the metal shield covering the battery connector.
  12. Samsung Galaxy Note10 Motherboard Replacement, Disconnect the battery: stap 12, afbeelding 1 van 2 Samsung Galaxy Note10 Motherboard Replacement, Disconnect the battery: stap 12, afbeelding 2 van 2
    • While holding the metal shield up and out of the way, use the pointed end of a spudger to pry up the battery connector to disconnect it.
  13. Samsung Galaxy Note10 Motherboard Replacement, Disconnect the wireless charging coil: stap 13, afbeelding 1 van 2 Samsung Galaxy Note10 Motherboard Replacement, Disconnect the wireless charging coil: stap 13, afbeelding 2 van 2
    • Use the pointed end of a spudger to disconnect the wireless charging coil connector from the motherboard.
  14. Samsung Galaxy Note10 Motherboard Replacement, Remove the wireless charging coil: stap 14, afbeelding 1 van 3 Samsung Galaxy Note10 Motherboard Replacement, Remove the wireless charging coil: stap 14, afbeelding 2 van 3 Samsung Galaxy Note10 Motherboard Replacement, Remove the wireless charging coil: stap 14, afbeelding 3 van 3
    • Tilt the metal shielding up so you can grip it with your fingers.
    • Peel the wireless charging coil up and away from the device.
    • The wireless charging coil is secured to the phone with some light adhesive.
    • Remove the wireless charging coil.
  15. Samsung Galaxy Note10 Motherboard Replacement, Front-Facing Camera: stap 15, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the four 4 mm screws securing the top plastic cover.
  16. Samsung Galaxy Note10 Motherboard Replacement: stap 16, afbeelding 1 van 3 Samsung Galaxy Note10 Motherboard Replacement: stap 16, afbeelding 2 van 3 Samsung Galaxy Note10 Motherboard Replacement: stap 16, afbeelding 3 van 3
    • Use a pair of tweezers to pivot the top plastic cover up and off of the phone.
  17. Samsung Galaxy Note10 Motherboard Replacement: stap 17, afbeelding 1 van 2 Samsung Galaxy Note10 Motherboard Replacement: stap 17, afbeelding 2 van 2
    • Use the pointed end of a spudger to pry the front-facing camera connector straight up from the motherboard.
  18. Samsung Galaxy Note10 Motherboard Replacement: stap 18, afbeelding 1 van 2 Samsung Galaxy Note10 Motherboard Replacement: stap 18, afbeelding 2 van 2
    • Remove the front-facing camera.
  19. Samsung Galaxy Note10 Motherboard Replacement, Remove the loudspeaker screws: stap 19, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the five 4 mm screws securing the loudspeaker.
  20. Samsung Galaxy Note10 Motherboard Replacement, Remove the loudspeaker: stap 20, afbeelding 1 van 3 Samsung Galaxy Note10 Motherboard Replacement, Remove the loudspeaker: stap 20, afbeelding 2 van 3 Samsung Galaxy Note10 Motherboard Replacement, Remove the loudspeaker: stap 20, afbeelding 3 van 3
    • Use a pair of tweezers to remove the loudspeaker.
  21. Samsung Galaxy Note10 Motherboard Replacement, Remove the interconnect cables: stap 21, afbeelding 1 van 3 Samsung Galaxy Note10 Motherboard Replacement, Remove the interconnect cables: stap 21, afbeelding 2 van 3 Samsung Galaxy Note10 Motherboard Replacement, Remove the interconnect cables: stap 21, afbeelding 3 van 3
    • Use the pointed end of a spudger to disconnect the main interconnect cable from the motherboard.
    • Disconnect the secondary interconnect cable from the motherboard.
  22. Samsung Galaxy Note10 Motherboard Replacement: stap 22, afbeelding 1 van 3 Samsung Galaxy Note10 Motherboard Replacement: stap 22, afbeelding 2 van 3 Samsung Galaxy Note10 Motherboard Replacement: stap 22, afbeelding 3 van 3
    • Use the pointed end of a spudger to disconnect the main interconnect cable from the daughterboard.
    • Disconnect the secondary interconnect cable from the daughterboard.
  23. Samsung Galaxy Note10 Motherboard Replacement: stap 23, afbeelding 1 van 2 Samsung Galaxy Note10 Motherboard Replacement: stap 23, afbeelding 2 van 2
    • Remove both interconnect cables.
  24. Samsung Galaxy Note10 Motherboard Replacement, Remove the SIM card tray: stap 24, afbeelding 1 van 2 Samsung Galaxy Note10 Motherboard Replacement, Remove the SIM card tray: stap 24, afbeelding 2 van 2
    • Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the top edge of the phone.
    • Press firmly to eject the tray.
    • Remove the SIM card tray.
  25. Samsung Galaxy Note10 Motherboard Replacement, Disconnect motherboard connectors: stap 25, afbeelding 1 van 2 Samsung Galaxy Note10 Motherboard Replacement, Disconnect motherboard connectors: stap 25, afbeelding 2 van 2
    • Use the pointed end of a spudger to disconnect the display cable from the motherboard.
  26. Samsung Galaxy Note10 Motherboard Replacement: stap 26, afbeelding 1 van 3 Samsung Galaxy Note10 Motherboard Replacement: stap 26, afbeelding 2 van 3 Samsung Galaxy Note10 Motherboard Replacement: stap 26, afbeelding 3 van 3
    • Use the pointed end of a spudger to disconnect the side button connector from the motherboard.
    • Disconnect the touch layer connector from the motherboard.
  27. Samsung Galaxy Note10 Motherboard Replacement: stap 27, afbeelding 1 van 2 Samsung Galaxy Note10 Motherboard Replacement: stap 27, afbeelding 2 van 2
    • Use the pointed end of a spudger to disconnect the S-Pen charging coil connector from the motherboard.
  28. Samsung Galaxy Note10 Motherboard Replacement, Remove the motherboard: stap 28, afbeelding 1 van 3 Samsung Galaxy Note10 Motherboard Replacement, Remove the motherboard: stap 28, afbeelding 2 van 3 Samsung Galaxy Note10 Motherboard Replacement, Remove the motherboard: stap 28, afbeelding 3 van 3
    • Use the pointed end of a spudger to pry up the motherboard enough to grip it with your fingers.
    • Remove the motherboard.
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
4 andere personen hebben deze handleiding voltooid.
Carsten Frauenheim
114.167 Reputatie
338 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
17.204 handleidingen geschreven
Één opmerking
missing steps to remove piece above the wireless coil. You guys went from wireless coil to the bottom of the phone to remove the daughter board and skipped entirely how to remove the top piece above the coil.
Jose - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 81
Altijd: 5,442
