Ga door naar hoofdinhoud
Samsung BD-F5700 Power Cord Replacement
Nicholas Straits
Nicholas Straits en 5 andere bijdragers
Voor het laatst geüpdatet op December 17, 2021
5 minuten
Eenvoudig
In this guide, you will learn how to replace or remove the power cord to a Samsung BD-F5700 Blu-Ray player. You will see step-by-step how to open the device, which screws to remove, and how to ultimately remove the power cord from the device. This repair would be needed if your device is no longer getting power to it. Always make sure the device is unplugged before beginning to work on it, as there is a chance of shock from exposed wiring.
Wat je nodig hebt
Gereedschap
  1. Samsung BD-F5700 Power Cord Replacement, Power Cord: stap 1, afbeelding 1 van 3 Samsung BD-F5700 Power Cord Replacement, Power Cord: stap 1, afbeelding 2 van 3 Samsung BD-F5700 Power Cord Replacement, Power Cord: stap 1, afbeelding 3 van 3
    • Use Phillips 0 Screwdriver to remove two (2), 10 mm rear screws.
    • Use the iFixit opening tool to help separate the top plastic casing from the bottom metal casing.
    • When opening the device, be careful to not damage the ribbon cable circled in image 3.
  2. Samsung BD-F5700 Power Cord Replacement: stap 2, afbeelding 1 van 3 Samsung BD-F5700 Power Cord Replacement: stap 2, afbeelding 2 van 3 Samsung BD-F5700 Power Cord Replacement: stap 2, afbeelding 3 van 3
    • Use Phillips 0 screwdriver to remove two (2), 10 mm screws from the plastic cover.
    • Remove plastic cover from board.
  3. Samsung BD-F5700 Power Cord Replacement: stap 3, afbeelding 1 van 2 Samsung BD-F5700 Power Cord Replacement: stap 3, afbeelding 2 van 2
    • Pull upward on back of the black and white wire to dislocate the black tab piece from device.
    • To remove the cord from the device entirely, press on the white tab in the device and gently pull.
  4. Samsung BD-F5700 Power Cord Replacement: stap 4, afbeelding 1 van 1
    • Insert the iFixit Opening tool into the black tab on the power cord, and use leverage to open the black tab.
    • Pull the tab off the wire so that it can be placed on the replacement cord.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nicholas Straits
236 Reputatie
1 Handleiding geschreven
USF Tampa, Team S16-G4, Boczar Spring 2018 Lid van USF Tampa, Team S16-G4, Boczar Spring 2018
USFT-BOCZAR-S18S16G4
4 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 322
