Ga door naar hoofdinhoud
SIM Card Slot Repair
Cyndal Burns
Cyndal Burns en 2 andere bijdragers
Voor het laatst geüpdatet op 8 aug. 2023
20 minuten
Gemiddeld
Very often, people must buy a completely new phone when something small like the soldering on the SIM slot breaks.
This guide provides brief instructions on how to fix a faulty or broken connection on a SIM card reader.
Wat je nodig hebt
Gereedschap
Toon meer…
  1. SIM Card Slot Repair, SIM Card Slot Repair: stap 1, afbeelding 1 van 3 SIM Card Slot Repair, SIM Card Slot Repair: stap 1, afbeelding 2 van 3 SIM Card Slot Repair, SIM Card Slot Repair: stap 1, afbeelding 3 van 3
    • Start by getting your work space set up and clear of clutter.
    • Remove the back of the phone.
    • Remove the battery and set it aside.
  2. SIM Card Slot Repair: stap 2, afbeelding 1 van 2 SIM Card Slot Repair: stap 2, afbeelding 2 van 2
    • Remove the six 2.3mm screws with a "T5" Screwdriver.
    • Remove the 2 additional 2.3mm screws from the side opposite the volume and power button.
    • When you open the back of the phone the camera and speaker will be attached to the part that you are removing.
  3. SIM Card Slot Repair: stap 3, afbeelding 1 van 3 SIM Card Slot Repair: stap 3, afbeelding 2 van 3 SIM Card Slot Repair: stap 3, afbeelding 3 van 3
    • Inspect the sim slot to find where the factory solder might be broken.
    • Once found dip the soldering gun in the flux to prevent the solder sticking to the gun.
    • Use the 60/40 lead solder to repair the damaged spot on the sim slot.
    • Do NOT allow the solder to touch any other connections as it could cause the device to short out or no function properly.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Bereid je voor op toekomstige reparaties
Winkelen
1Gids Commentaar
I recently purchased a custom built phone which has the best parts of Android with the IMAX 13 camera my SIM tray broke and I can't seem to find anyone that has or knows which kind goes here is there any way you could help me
Bryan S. - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 38
Afgelopen 30 dagen: 128
Altijd: 14,421
