Ga door naar hoofdinhoud
Deze demontage is geen reparatiehandleiding. Om je Rubik's Cube te repareren, gebruik onze reparatiehandleidingen.
  1. Rubik's Cube Teardown, Rubik's Cube Teardown: stap 1, afbeelding 1 van 3 Rubik's Cube Teardown, Rubik's Cube Teardown: stap 1, afbeelding 2 van 3 Rubik's Cube Teardown, Rubik's Cube Teardown: stap 1, afbeelding 3 van 3
    • Turn the top row so that each corner is roughly halfway between the sides
    • Push the pieces up until they pop out of the cube, then, slide the rest out
    • Repeat this process until you clear the level
  2. Rubik's Cube Teardown: stap 2, afbeelding 1 van 2 Rubik's Cube Teardown: stap 2, afbeelding 2 van 2
    • You should be able to just directly pull out the rest of the blocks, like so
    • And there you have it!
    • You'll have the center piece, with the six centers of the six sides, the turning mechanism
  3. Rubik's Cube Teardown: stap 3, afbeelding 1 van 2 Rubik's Cube Teardown: stap 3, afbeelding 2 van 2
    • To reassemble, snap all the pieces back into place, and try not to rotate the faces.
    • It helps to start with the middle pieces first
    • Don't be afraid to use force!
    • Once you have the middle pieces in it's pretty simple to just push in the corner pieces
    • Again- don't be afraid to use force!
Bereid je voor op toekomstige reparaties
Winkelen
rab777hp
20.379 Reputatie
3 handleidingen geschreven
OPEN Lid van OPEN
Community
85 Leden
28 handleidingen geschreven
6Gids Commentaar
I hated this thing. I disassembled mine with a .22 hollow point at 100 yards. Yes, It felt great!
mpias - Antwoord
lol don’t blame you, can’t stand the thing
Luke -
that method just broke my rubiks my cube.. thanks anyway
hamzamagdy888 - Antwoord
my middle peices came out cant fix it
jax - Antwoord
can someone tell me how to fix it
jax - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 56
Altijd: 25,130
