Ga door naar hoofdinhoud
Replacement the hard disk on Dell XPS 12 9Q23
Schwarzer
Schwarzer en een andere bijdrager
Voor het laatst geüpdatet op March 18, 2024
15 minuten
Gemiddeld
Uitgelichte handleiding
Door de gemeenschap gemaakte handleiding
Do you want to change your hard disk to increase its capacity or replace it, because it no longer works? Perfect, you've come to the right place, this tutorial is for you!
Wat je nodig hebt
Gereedschap
  1. Replacement the hard disk on Dell XPS 12 9Q23, Battery: stap 1, afbeelding 1 van 1
    • Pop the center cover open on the bottom cover.
    • Remove the center screw with a #00 Phillips screwdriver.
    • Use a T5 Torx screwdriver for the remaining screws around the edge of the bottom cover.
  2. Replacement the hard disk on Dell XPS 12 9Q23: stap 2, afbeelding 1 van 1
    • Carefully remove back panel after all screws have been removed.
  3. Replacement the hard disk on Dell XPS 12 9Q23: stap 3, afbeelding 1 van 1
    • After the back panel has been removed, disconnect the battery to prevent electrical shock
  4. Replacement the hard disk on Dell XPS 12 9Q23: stap 4, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the 8 screws that secure the battery.
  5. Replacement the hard disk on Dell XPS 12 9Q23, Remove the battery: stap 5, afbeelding 1 van 1
    • Once all the screws have been removed the battery is now safe to extract
  6. Replacement the hard disk on Dell XPS 12 9Q23, Adhesive tape: stap 6, afbeelding 1 van 1
    • We removed the battery to avoid electric shocks.
    • Remove the adhesive tape.
  7. Replacement the hard disk on Dell XPS 12 9Q23, Remove the hard disk drive: stap 7, afbeelding 1 van 2 Replacement the hard disk on Dell XPS 12 9Q23, Remove the hard disk drive: stap 7, afbeelding 2 van 2
    • Remove the screw with a #00 Phillips screwdriver.
    • Remove the hard disk from its location.
Conclusie
To reassemble your device, follow the instructions in reverse order.
Met dank aan deze vertalers:
fr en
100%
Schwarzer helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
Schwarzer
5.049 Reputatie
13 handleidingen geschreven
i.Fixit FR Team Lid van i.Fixit FR Team
Community
3 Leden
40 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 43
Altijd: 1,985
