Ga door naar hoofdinhoud
Repairing Sony Cyber-shot DSC-W290 Motherboard
Evan Mayer
Evan Mayer en 6 andere bijdragers
Voor het laatst geüpdatet op December 16, 2020
40 minuten
Moeilijk
Thorough knowledge of disassembling the camera is necessary for replacing the motherboard.
Wat je nodig hebt
Onderdelen
Gereedschap
Toon meer…
  1. Repairing Sony Cyber-shot DSC-W290 Motherboard, Battery: stap 1, afbeelding 1 van 1
    • Find the hatch labeled "open" on the left side of the bottom of the camera.
    • Slide the hatch in the direction that the arrow is pointing. The hatch will open outward on its own.
  2. Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 2, afbeelding 1 van 1
    • Slide the blue locking tab to release the battery.
    • Slide the battery out of the camera.
  3. Repairing Sony Cyber-shot DSC-W290 Motherboard, Outer Casing: stap 3, afbeelding 1 van 2 Repairing Sony Cyber-shot DSC-W290 Motherboard, Outer Casing: stap 3, afbeelding 2 van 2
    • Replace hatch and rotate camera 180 degrees. You should still be looking at the bottom of the camera.
    • Remove the four 2.5mm Phillips #0 screws.
  4. Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 4, afbeelding 1 van 3 Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 4, afbeelding 2 van 3 Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Turn the camera so the left side-panel reading "5x Optical Zoom" faces you.
    • Remove the two 2.5mm Phillips #0 screws.
    • You may have to remove the screws with a pair of tweezers when the screws are almost out.
  5. Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 5, afbeelding 1 van 3 Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 5, afbeelding 2 van 3 Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 5, afbeelding 3 van 3
    • Turn the camera so the right side faces you.
  6. Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 6, afbeelding 1 van 1
    • Rotate camera so that the back is facing you.
    • Pull the back casing directly away from the LCD screen.
  7. Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 7, afbeelding 1 van 2 Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 7, afbeelding 2 van 2
    • Turn the camera so that the left side is facing you.
    • Pull the left side-panel off of the camera.
  8. Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 8, afbeelding 1 van 2 Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 8, afbeelding 2 van 2
    • Turn camera so that the front of the camera is facing you.
    • Pull the front casing directly away from the camera.
    • The right side panel may fall off when you take the front panel off.
  9. Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 9, afbeelding 1 van 2 Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 9, afbeelding 2 van 2
    • Turn the camera so that the right side is facing you.
    • Pull the right side-panel away from the rest of the camera.
  10. Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 10, afbeelding 1 van 2 Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 10, afbeelding 2 van 2
    • This is what your camera should look like now that you have removed the casing from all sides.
  11. Repairing Sony Cyber-shot DSC-W290 Motherboard, LCD Assembly: stap 11, afbeelding 1 van 1
    • Gently pull the LCD and its casing away from the motherboard as shown.
    • Be careful not to rip out any ribbon cables.
  12. Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 12, afbeelding 1 van 2 Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 12, afbeelding 2 van 2
    • Disconnect the small ribbon-wire by gently pulling on the small ribbon-wire where it connects with the motherboard.
    • Do not use excessive force to remove the wire because this may cause it to tear.
  13. Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 13, afbeelding 1 van 2 Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 13, afbeelding 2 van 2
    • Disconnect the large ribbon-wire by pulling on the large ribbon-wire where it connects to the motherboard.
  14. Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 14, afbeelding 1 van 1
    • Pull the LCD and its casing away from the rest of the camera.
  15. Repairing Sony Cyber-shot DSC-W290 Motherboard, Flash Bulb Assembly: stap 15, afbeelding 1 van 2 Repairing Sony Cyber-shot DSC-W290 Motherboard, Flash Bulb Assembly: stap 15, afbeelding 2 van 2
    • Turn the camera so the back is facing you.
    • Remove the 2.5mm Philips #0 screw at the top of the camera.
  16. Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 16, afbeelding 1 van 3 Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 16, afbeelding 2 van 3 Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 16, afbeelding 3 van 3
    • Tilt top casing up and towards you.
    • Carefully remove the right ribbon-wire from the top camera panel by pulling where the wire connects to the top.
    • Make sure to hold the camera with your thumb on the white square to ensure the ribbon-wire is not disconnected from the motherboard.
    • Carefully remove the left ribbon-wire from the top camera panel by pulling where the wire connects to the top.
  17. Repairing Sony Cyber-shot DSC-W290 Motherboard, Lens Assembly: stap 17, afbeelding 1 van 3 Repairing Sony Cyber-shot DSC-W290 Motherboard, Lens Assembly: stap 17, afbeelding 2 van 3 Repairing Sony Cyber-shot DSC-W290 Motherboard, Lens Assembly: stap 17, afbeelding 3 van 3
    • Flash capacitors are dangerous! Be extremely careful when removing the capacitor from the camera. You can get shocked BADLY!
    • Remove the flash capacitor from the lens assembly.
    • Carefully place the flash capacitor away from where you are working.
  18. Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 18, afbeelding 1 van 3 Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 18, afbeelding 2 van 3 Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 18, afbeelding 3 van 3
    • Carefully disconnect the top ribbon-wire from the motherboard by pulling where the wire connects to the motherboard.
  19. Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 19, afbeelding 1 van 3 Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 19, afbeelding 2 van 3 Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 19, afbeelding 3 van 3
    • Disconnect the top remaining ribbon-wire by carefully pulling at the base of where the wire connects to the motherboard.
  20. Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 20, afbeelding 1 van 3 Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 20, afbeelding 2 van 3 Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 20, afbeelding 3 van 3
    • Pull the Lens Assembly away from the motherboard.
    • You have now removed the Lens Assembly from the camera.
  21. Repairing Sony Cyber-shot DSC-W290 Motherboard, Motherboard: stap 21, afbeelding 1 van 3 Repairing Sony Cyber-shot DSC-W290 Motherboard, Motherboard: stap 21, afbeelding 2 van 3 Repairing Sony Cyber-shot DSC-W290 Motherboard, Motherboard: stap 21, afbeelding 3 van 3
    • Remove the red clip that holds the motherboard to its casing.
  22. Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 22, afbeelding 1 van 3 Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 22, afbeelding 2 van 3 Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 22, afbeelding 3 van 3
    • Pull back the small gray clip located on the right side of the camera to release the motherboard from its casing.
  23. Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 23, afbeelding 1 van 3 Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 23, afbeelding 2 van 3 Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 23, afbeelding 3 van 3
    • Lift the motherboard from the casing.
    • Carefully remove the large ribbon-wire by pulling the wire where it connects with the motherboard.
    • In order to completely remove the motherboard, you must desolder the small ribbon wire from the casing.
  24. Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 24, afbeelding 1 van 3 Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 24, afbeelding 2 van 3 Repairing Sony Cyber-shot DSC-W290 Motherboard: stap 24, afbeelding 3 van 3
    • Flip the motherboard up to turn it over.
    • When de-soldering, be careful not to burn yourself or the motherboard. You can damage or destroy the motherboard or the ribbon wire by applying too much heat.
    • Carefully de-solder the three connectors from the ribbon wire to the motherboard.
    • You have now removed the motherboard.
Conclusie
Evan Mayer
336 Reputatie
5 handleidingen geschreven
Cal Poly, Team 7-54, Amido Fall 2010 Lid van Cal Poly, Team 7-54, Amido Fall 2010
CPSU-AMIDO-F10S7G54
4 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 11
Altijd: 4,006
