Inleiding
This guide outlines how to remove the lithium-ion battery in the Razer Blade Stealth 2017. Battery replacement may be necessary if the battery is not charging, not powering the computer, swollen, leaking, or not lasting as long as you would like. Some tools are required for this replacement.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
For optimal performance, after completing this guide, calibrate your newly installed battery.
9 andere personen hebben deze handleiding voltooid.
