Ga door naar hoofdinhoud
Razer Blade RZ09-0102 Battery Replacement
Wat je nodig hebt
  1. Razer Blade RZ09-0102 Battery Replacement, Rear Panel: stap 1, afbeelding 1 van 1
    • Before you begin, be sure to turn off your laptop.
    • Using a Torx T5 screwdriver, remove the ten 1/8 inch screws securing the back cover.
    • Remove the back cover.
    I need the screws is there any way I can get them?
    Lupita Muro - Antwoord
  2. Razer Blade RZ09-0102 Battery Replacement, Battery: stap 2, afbeelding 1 van 2 Razer Blade RZ09-0102 Battery Replacement, Battery: stap 2, afbeelding 2 van 2
    • Remove the seven screws holding the battery in place using a Phillips #0 screwdriver.
  3. Razer Blade RZ09-0102 Battery Replacement: stap 3, afbeelding 1 van 1
    • Unlock the ZIF connectors securing the right ribbon cable.
    • To unlock a ZIF connector, use an opening tool or your fingernail to flip up the small, hinged locking flap.
    • Carefully pull the two ribbon cables out of their sockets.
  4. Razer Blade RZ09-0102 Battery Replacement: stap 4, afbeelding 1 van 1
    • Use an opening tool to unlock the ZIF connector securing the white ribbon over the battery.
    You know where I can buy that kind white ribbon, it hard find anywhere.
    loona.ot12 - Antwoord
  5. Razer Blade RZ09-0102 Battery Replacement: stap 5, afbeelding 1 van 2 Razer Blade RZ09-0102 Battery Replacement: stap 5, afbeelding 2 van 2
    • Carefully pull out the two connectors out of their sockets.
    • Pull parallel to the motherboard, not straight up.
  6. Razer Blade RZ09-0102 Battery Replacement: stap 6, afbeelding 1 van 2 Razer Blade RZ09-0102 Battery Replacement: stap 6, afbeelding 2 van 2
    • Pull the wide battery connector towards the battery to disconnect it from the motherboard.
  7. Razer Blade RZ09-0102 Battery Replacement: stap 7, afbeelding 1 van 2 Razer Blade RZ09-0102 Battery Replacement: stap 7, afbeelding 2 van 2
    • Remove the battery from the laptop.
    I lost some of the screws! What are the right replacement screws for the back cover and the battery?
    Anon - Antwoord
Conclusie
For optimal performance, after completing this guide, calibrate your newly installed battery.
6 andere personen hebben deze handleiding voltooid.
2Gids Commentaar
Hey Nicole, thank you for writing this fantastic guide. Do you have any recommendations for vendors or websites for this specific battery replacement?
Erfan Moradi - Antwoord
My dudes, anyone can tell me what model is the RZ09-0102 battery connector and where to order the motherboard side?
A friends laptop got the connector melted *moisture* and I can’t identify this dense 30-pin oedipus.
Giorgi Kikuashvili - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 52
Altijd: 26,426
