Inleiding
Use this guide to replace or upgrade the PCIe M.2 2280 SSD in your Razer Blade 15" (2020) laptop.
Note: This laptop doesn't support SATA M.2 SSDs.
Before you perform this repair, back up your existing SSD if possible. If you're replacing the SSD where your operating system is installed, familiarize yourself with a disk cloning utility so you’ll be ready to migrate your data to the new SSD. There are many tools to do this, but this article is a good place to start if you're unfamiliar with the process.
Wat je nodig hebt
Unplug all cables and fully shut down your laptop.
Close the lid and flip your laptop over so the back cover faces up.
Use a T5 Torx driver to remove the ten 3.7 mm-long screws securing the back cover.
Use a finger to pry up the right side of the back cover, starting at the Ethernet port cutout.
Remove the back cover slowly, as to avoid tearing the thermal pads underneath.
Lay the back cover down on its rubber feet to avoid damaging the thermal pads on its underside.
Apply a heated iOpener to the battery cable tape for one minute.
Use the flat end of a spudger to push the square tab on the battery connector and slide it out of its socket.
Use a Phillips screwdriver to remove the 3.1 mm screw securing the SSD.
