Ga door naar hoofdinhoud
Punkt MP02 Keyboard Membrane Replacement
Wat je nodig hebt
  1. Punkt MP02 Keyboard Membrane Replacement, Battery: stap 1, afbeelding 1 van 2 Punkt MP02 Keyboard Membrane Replacement, Battery: stap 1, afbeelding 2 van 2
    • Use a SIM card eject tool to to eject and remove the SIM card tray on the side of the phone.
    Vraag FixBot
    Voeg opmerking toe
  2. Punkt MP02 Keyboard Membrane Replacement: stap 2, afbeelding 1 van 2 Punkt MP02 Keyboard Membrane Replacement: stap 2, afbeelding 2 van 2
    • The back panel is held on by glue and multiple tabs.
    • Slide a Jimmy into the seam between the back panel and the chassis.
    • Slide the Jimmy around the perimeter to release the back panel, with care not to damage the retaining clips.
    • Clean any old adhesive with a spudger and isopropyl alcohol, then apply new adhesive to the back panel before reinstalling it.
    Vraag FixBot
    Voeg opmerking toe
  3. Punkt MP02 Keyboard Membrane Replacement: stap 3, afbeelding 1 van 3 Punkt MP02 Keyboard Membrane Replacement: stap 3, afbeelding 2 van 3 Punkt MP02 Keyboard Membrane Replacement: stap 3, afbeelding 3 van 3
    • Use a Phillips screwdriver to remove the two adjacent 3 mm Phillips screws.
    Vraag FixBot
    Voeg opmerking toe
  4. Punkt MP02 Keyboard Membrane Replacement: stap 4, afbeelding 1 van 3 Punkt MP02 Keyboard Membrane Replacement: stap 4, afbeelding 2 van 3 Punkt MP02 Keyboard Membrane Replacement: stap 4, afbeelding 3 van 3
    • Insert a Jimmy into the seam between the front and back case.
    • Slide the Jimmy around the perimeter while prying to separate the front and back case.
    Vraag FixBot
    Voeg opmerking toe
  5. Punkt MP02 Keyboard Membrane Replacement: stap 5, afbeelding 1 van 2 Punkt MP02 Keyboard Membrane Replacement: stap 5, afbeelding 2 van 2
    • Use a spudger to pry up and disconnect the battery press connector.
    • Make sure to pry under the connector itself and not on the board.
    Vraag FixBot
    Voeg opmerking toe
  6. Punkt MP02 Keyboard Membrane Replacement: stap 6, afbeelding 1 van 2 Punkt MP02 Keyboard Membrane Replacement: stap 6, afbeelding 2 van 2
    • Gently pry the battery off with the spudger tool.
    • Take care not to bend, warp, or puncture the battery during removal.
    Vraag FixBot
    Voeg opmerking toe
  7. Punkt MP02 Keyboard Membrane Replacement, Screen: stap 7, afbeelding 1 van 3 Punkt MP02 Keyboard Membrane Replacement, Screen: stap 7, afbeelding 2 van 3 Punkt MP02 Keyboard Membrane Replacement, Screen: stap 7, afbeelding 3 van 3
    • Remove the six 3 mm-long Phillips screws located on the board beneath the battery.
    Vraag FixBot
    Voeg opmerking toe
  8. Punkt MP02 Keyboard Membrane Replacement: stap 8, afbeelding 1 van 3 Punkt MP02 Keyboard Membrane Replacement: stap 8, afbeelding 2 van 3 Punkt MP02 Keyboard Membrane Replacement: stap 8, afbeelding 3 van 3
    • Remove the antenna coaxial connectors on the board with a spudger by gently prying straight up where they are connected on the board.
    Vraag FixBot
    Voeg opmerking toe
  9. Punkt MP02 Keyboard Membrane Replacement: stap 9, afbeelding 1 van 3 Punkt MP02 Keyboard Membrane Replacement: stap 9, afbeelding 2 van 3 Punkt MP02 Keyboard Membrane Replacement: stap 9, afbeelding 3 van 3
    • Flip up the two black locking flaps securing each of the two ribbon cables.
    • Disconnect the two ribbon cables.
    Vraag FixBot
    Voeg opmerking toe
  10. Punkt MP02 Keyboard Membrane Replacement: stap 10, afbeelding 1 van 2 Punkt MP02 Keyboard Membrane Replacement: stap 10, afbeelding 2 van 2
    • Using your thumbs, push the board up so that the clip can slide out of the indent.
    • Use a spudger to gently separate the boards.
    • Ensure that the antennae slide through the holes—do not accidentally pull these off.
    Vraag FixBot
    Voeg opmerking toe
  11. Punkt MP02 Keyboard Membrane Replacement: stap 11, afbeelding 1 van 3 Punkt MP02 Keyboard Membrane Replacement: stap 11, afbeelding 2 van 3 Punkt MP02 Keyboard Membrane Replacement: stap 11, afbeelding 3 van 3
    • Use a spudger to lift and disconnect the screen press connector.
    • Make sure to pry up on the edge of the connector, not the board itself.
    • Remove the screen.
    Vraag FixBot
    Voeg opmerking toe
  12. Punkt MP02 Keyboard Membrane Replacement, Keyboard Membrane: stap 12, afbeelding 1 van 3 Punkt MP02 Keyboard Membrane Replacement, Keyboard Membrane: stap 12, afbeelding 2 van 3 Punkt MP02 Keyboard Membrane Replacement, Keyboard Membrane: stap 12, afbeelding 3 van 3
    • Remove the 3 (3mm) Phillips head screws from the board.
    Vraag FixBot
    Voeg opmerking toe
  13. Punkt MP02 Keyboard Membrane Replacement: stap 13, afbeelding 1 van 2 Punkt MP02 Keyboard Membrane Replacement: stap 13, afbeelding 2 van 2
    • Use a spudger to gently pry the board up and remove it.
    Vraag FixBot
    Voeg opmerking toe
  14. Punkt MP02 Keyboard Membrane Replacement: stap 14, afbeelding 1 van 3 Punkt MP02 Keyboard Membrane Replacement: stap 14, afbeelding 2 van 3 Punkt MP02 Keyboard Membrane Replacement: stap 14, afbeelding 3 van 3
    • Peel the keyboard membrane off the phone casing.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Gloria Enchill
97 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 25
Altijd: 107
