Inleiding
If the outer casing of your Punkt MP02 is damaged, cracked, or old, you may consider replacing it. Using this guide, you can successfully replace the casing of your phone and keep all other components inside safe. Before you begin, backup important data, and power off the device to ensure no data loss throughout the process.
Wat je nodig hebt
Use a SIM card eject tool to to eject and remove the SIM card tray on the side of the phone.
Remove the six 3 mm-long Phillips screws located on the board beneath the battery.
Remove the speaker from the top of the back phone casing using the spudger tool.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
