Ga door naar hoofdinhoud
Photive Hydra Speaker Replacement
Andrew Chase
Andrew Chase en 4 andere bijdragers
Voor het laatst geüpdatet op January 20, 2025
Geen schatting
Gemiddeld
Betere introductie
Ontbrekende informatie
In this guide you will use a #1 and #1.5 screwdriver to remove various screws and components. Once you have gained access to the speaker you will have to use creative techniques to remove speaker.
Wat je nodig hebt
Gereedschap
Toon meer…
  1. Photive Hydra Speaker Replacement, Face Plate and Back Plate: stap 1, afbeelding 1 van 1
    • Unscrew all twelve Hex Head 1.5 (Length-3/8", Head- 1/8") screws using a 1.5mm hex screwdriver.
  2. Photive Hydra Speaker Replacement: stap 2, afbeelding 1 van 2 Photive Hydra Speaker Replacement: stap 2, afbeelding 2 van 2
    • Use a plastic opening tool to pry off the face plate.
  3. Photive Hydra Speaker Replacement: stap 3, afbeelding 1 van 1
    • Remove the rubber casing by using your fingers to pull off. Be sure not tear or rip rubber casing.
  4. Photive Hydra Speaker Replacement: stap 4, afbeelding 1 van 1
    • Flip the device upside down and remove all eight Phillips (Length-3/8", Head-1/8") Screws using a standard #1 Phillips screwdriver.
  5. Photive Hydra Speaker Replacement: stap 5, afbeelding 1 van 2 Photive Hydra Speaker Replacement: stap 5, afbeelding 2 van 2
    • Use plastic opening tool to pry off back plate.
    • Move the plastic opening tool along the the device to further pry open the device.
    • Be careful when taking this plate off. You may accidentally damage the water proof seal.
  6. Photive Hydra Speaker Replacement, Speaker: stap 6, afbeelding 1 van 2 Photive Hydra Speaker Replacement, Speaker: stap 6, afbeelding 2 van 2
    • Identify the two Phillips (Length-5/16" Head-1/8") screws holding the speaker in place and remove them.
  7. Photive Hydra Speaker Replacement: stap 7, afbeelding 1 van 1
    • Remove the bracket holding the speaker in place.
  8. Photive Hydra Speaker Replacement: stap 8, afbeelding 1 van 1
    • Disconnect the wires that are connected from the speaker to the motherboard.
  9. Photive Hydra Speaker Replacement: stap 9, afbeelding 1 van 3 Photive Hydra Speaker Replacement: stap 9, afbeelding 2 van 3 Photive Hydra Speaker Replacement: stap 9, afbeelding 3 van 3
    • After all extra components are out of the way, you will need to remove the adhesive holding the speaker using either a heating gun or the iOpener kit (both can be purchased under the Parts and Tools Store section of the menu bar). Once that is completed, replace the broken speaker with the new, functional speaker.
  10. Photive Hydra Speaker Replacement: stap 10, afbeelding 1 van 2 Photive Hydra Speaker Replacement: stap 10, afbeelding 2 van 2
    • Identify the four Phillips (Length-5/16", Head-1/8") screws holding the speaker housing (below the battery) and remove them.
  11. Photive Hydra Speaker Replacement: stap 11, afbeelding 1 van 1
    • Identify motherboard.
  12. Photive Hydra Speaker Replacement: stap 12, afbeelding 1 van 1
    • Disconnect highlighted electrical cords.
  13. Photive Hydra Speaker Replacement: stap 13, afbeelding 1 van 1
    • Disconnect second highlighted electrical cord.
  14. Photive Hydra Speaker Replacement: stap 14, afbeelding 1 van 1
    • Pull motherboard up and away in order to remove it.
  15. Photive Hydra Speaker Replacement: stap 15, afbeelding 1 van 1
    • Identify the two Phillips (Length-5/16", Head-1/8") screws holding the speaker in place and remove them.
  16. Photive Hydra Speaker Replacement: stap 16, afbeelding 1 van 3 Photive Hydra Speaker Replacement: stap 16, afbeelding 2 van 3 Photive Hydra Speaker Replacement: stap 16, afbeelding 3 van 3
    • Upon removing the plastic bracket, you will need to remove the adhesive using either a heating gun or the iOpener kit (both can be purchased under the Parts and Tools Store section of the menu bar) that is holding the speaker in place. Once that is completed, replace the broken speaker with a new, functional speaker.
Conclusie
Andrew Chase
352 Reputatie
3 handleidingen geschreven
USF Tampa, Team 11-3, Cheng Spring 2016 Lid van USF Tampa, Team 11-3, Cheng Spring 2016
USFT-CHENG-S16S11G3
5 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 808
