Ga door naar hoofdinhoud
Pentax Spotmatic Light Meter Calibration
Sam Gustafson
Sam Gustafson en een andere bijdrager
Voor het laatst geüpdatet op December 11, 2024
10 minuten
Eenvoudig
Door de gemeenschap gemaakte handleiding
Over time, the reading of the light meter in the Spotmatic can drift. This guide explains how to adjust the variable resistor in the light meter circuit to improve its accuracy.
If you are adjusting the meter as part of a larger overhaul or disassembly, it's a good idea to replace the top cover before doing the adjustment. This will prevent stray light from influencing the light sensors.
  1. Pentax Spotmatic Light Meter Calibration, Open film door: stap 1, afbeelding 1 van 1
    • Open the flim door.
  2. Pentax Spotmatic Light Meter Calibration, Remove the rewind knob: stap 2, afbeelding 1 van 3 Pentax Spotmatic Light Meter Calibration, Remove the rewind knob: stap 2, afbeelding 2 van 3 Pentax Spotmatic Light Meter Calibration, Remove the rewind knob: stap 2, afbeelding 3 van 3
    • Place a thin, sturdy tool in the spindle fork.
    • Unscrew the rewind knob.
    • Use a spanner wrench to unscrew the retaining nut.
    • Remove the film reminder
    • Remove the spring washer.
    • Remove the friction plate.
    • Keep the film door open for the duration of the light meter adjustment. It can be difficult to open without the rewind knob installed.
    • Mount a lens on the camera.
    • Create a scene of known brightness in front of the camera.
    • Adjust the aperture, shutter speed and ISO to achieve proper exposure for the chosen scene.
    • Switch on the light meter.
  3. Pentax Spotmatic Light Meter Calibration, Make adjustments: stap 4, afbeelding 1 van 2 Pentax Spotmatic Light Meter Calibration, Make adjustments: stap 4, afbeelding 2 van 2
    • Use a pick to adjust the variable resistor through the opening in the top plate.
    • Turn it until the needle in the viewfinder is centered in the opening, indicating a proper exposure.
    • The adjustment resistor shown with the top cover removed.
    • Repeat steps 3 and 4 for several different light levels.
    • Since the Spotmatic only has one adjustment resistor, it may not be possible to center the needle at every light level. Make compromises as necessary.
Conclusie
Sam Gustafson
7.682 Reputatie
42 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 94
Altijd: 280
