Pentax LX ISO Resistor Cleaning
Inleiding
Ga naar stap 1The ISO resistor is a common point of failure in the Pentax LX. The component consists of a pair of feeler contacts sliding along a carbon filament. The resistance value created by this assembly communicates the ISO and exposure compensation settings to the camera. Over time the contacts can become oxidized and/or dirty resulting in erratic meter readings in the viewfinder. Cleaning the resistor can restore the camera to normal functionality.
Any disassembly of the LX body will compromise the weather sealing. New seals must be reapplied during final reassembly to restore weather proofing.
Wat je nodig hebt
Gereedschap
Place a thin tool in the rewind fork and unscrew the topside knob.
Remove the washer under the rewind knob.
Remove three #000 5.5 mm screws.
Remove exposure compensation dial assembly.
Remove washer.
Remove rubber seal.
Use a cotton bud and isopropyl alcohol to clean the surface of the resistive element.
Spray a plastic safe contact cleaner in the area of the feeler contacts.
Rotate the dial back and forth several times.
Check the resistance between the purple wire and ground. It should range from 7.5 kΩ to 200 kΩ with no dead spots.
Unsolder one purple wire.
Unsolder one green wire.
Unsolder two brown wires.
Remove three #00 screws.
