Pentax LX Front Lens Board Removal
Inleiding
Ga naar stap 1Any disassembly of the LX body will compromise the weather sealing. New seals must be reapplied during final reassembly to restore weather proofing.
Wat je nodig hebt
Gereedschap
Place a thin tool in the rewind fork and unscrew the topside knob.
Remove the washer under the rewind knob.
Remove three #000 5.5 mm screws.
Remove exposure compensation dial assembly.
Remove washer.
Remove rubber seal.
Remove one #00 X mm screw.
Remove one #00 2.5 mm screw.
Use isopropyl alcohol to soften the adhesive along the edge of the leatherette.
Use a dull spudger or scraper to peel off the covering.
Turn the self timer lever to the 9 o'clock position.
Loosen the entire right side leatherette in the same manner, then work it over and around the self timer lever to remove.
Remove the two cover plates under the leatherette.
They may stick to the covering adhesive and come off on their own.
This small plug may also be loose.
Unsolder one gray wire.
Unsolder two yellow wires.
Unsolder one blue wire.
Unsolder one red wire.
Unscrew four #00 X mm screws.
Unsolder one white wire.
Unsolder one pink wire.
Unsolder one light green wire.
Check the mounting points for shim washers. If they are loose, note the position and remove.
