Ga door naar hoofdinhoud
Parrot Skycontroller 2 USB Port Replacement
Wat je nodig hebt
  1. Parrot Skycontroller 2 USB Port Replacement, Battery: stap 1, afbeelding 1 van 3 Parrot Skycontroller 2 USB Port Replacement, Battery: stap 1, afbeelding 2 van 3 Parrot Skycontroller 2 USB Port Replacement, Battery: stap 1, afbeelding 3 van 3
    • Flip your controller face down.
    Vraag FixBot
    Voeg opmerking toe
  2. Parrot Skycontroller 2 USB Port Replacement: stap 2, afbeelding 1 van 1
    • Remove one 9mm screw using a #4 flathead screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  3. Parrot Skycontroller 2 USB Port Replacement: stap 3, afbeelding 1 van 3 Parrot Skycontroller 2 USB Port Replacement: stap 3, afbeelding 2 van 3 Parrot Skycontroller 2 USB Port Replacement: stap 3, afbeelding 3 van 3
    • Insert the plastic opening tool into the top of the cover and pry upwards to lift the battery cover.
    • Remove the cover by pulling up and out.
    Vraag FixBot
    Voeg opmerking toe
  4. Parrot Skycontroller 2 USB Port Replacement: stap 4, afbeelding 1 van 3 Parrot Skycontroller 2 USB Port Replacement: stap 4, afbeelding 2 van 3 Parrot Skycontroller 2 USB Port Replacement: stap 4, afbeelding 3 van 3
    • Pull the connectors out by gently pushing the tabs and pulling up on the connector.
    • Disconnect the battery from the remote by pressing the white tab and pulling the connectors apart.
    Vraag FixBot
    Voeg opmerking toe
  5. Parrot Skycontroller 2 USB Port Replacement: stap 5, afbeelding 1 van 2 Parrot Skycontroller 2 USB Port Replacement: stap 5, afbeelding 2 van 2
    • Remove the battery from its brackets by pulling up on the ends of the battery.
    Vraag FixBot
    Voeg opmerking toe
  6. Parrot Skycontroller 2 USB Port Replacement, USB Port: stap 6, afbeelding 1 van 1
    • Remove the seven black 11mm screws using the Torx TR6 screwdriver.
    • Pull back the sticker with your finger nail and remove one 11mm screws using the Torx TR6 screwdriver.
    • There is a hidden screw located behind the sticker in the battery compartment.
    Vraag FixBot
    Voeg opmerking toe
  7. Parrot Skycontroller 2 USB Port Replacement: stap 7, afbeelding 1 van 3 Parrot Skycontroller 2 USB Port Replacement: stap 7, afbeelding 2 van 3 Parrot Skycontroller 2 USB Port Replacement: stap 7, afbeelding 3 van 3
    • Remove the seven silver 4mm screws from around the edge of the top panel using the Torx TR6 screwdriver.
    • The opposite side to the third picture has a screw located on each side of the USB port.
    Vraag FixBot
    Voeg opmerking toe
  8. Parrot Skycontroller 2 USB Port Replacement: stap 8, afbeelding 1 van 1
    • Remove the battery compartment plate by pulling up and out.
    Vraag FixBot
    Voeg opmerking toe
  9. Parrot Skycontroller 2 USB Port Replacement: stap 9, afbeelding 1 van 2 Parrot Skycontroller 2 USB Port Replacement: stap 9, afbeelding 2 van 2
    • Remove the top plate by pushing on the corners with your hand.
    • Be careful to not pull too hard on the cable.
    Vraag FixBot
    Voeg opmerking toe
  10. Parrot Skycontroller 2 USB Port Replacement: stap 10, afbeelding 1 van 2 Parrot Skycontroller 2 USB Port Replacement: stap 10, afbeelding 2 van 2
    • Remove the face plate by pulling up and out.
    Vraag FixBot
    Voeg opmerking toe
  11. Parrot Skycontroller 2 USB Port Replacement: stap 11, afbeelding 1 van 3 Parrot Skycontroller 2 USB Port Replacement: stap 11, afbeelding 2 van 3 Parrot Skycontroller 2 USB Port Replacement: stap 11, afbeelding 3 van 3
    • Position the device so that the top panel is flat down on the table. You should have access to the USB Port.
    • Desolder the two connection points in the back of the USB port.
    • Desolder the four wires in the back of the USB port.
    • Remove the the component from the board.
    • Excessive heat can damage the port, so do not apply the soldering iron to the component for too long.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 27
Altijd: 1,177
