Ga door naar hoofdinhoud
Parrot Skycontroller 2 Buttons Replacement
Wat je nodig hebt
    1. Parrot Skycontroller 2 Buttons Replacement, Battery: stap 1, afbeelding 1 van 3 Parrot Skycontroller 2 Buttons Replacement, Battery: stap 1, afbeelding 2 van 3 Parrot Skycontroller 2 Buttons Replacement, Battery: stap 1, afbeelding 3 van 3
      • Flip your controller face down.
      Vraag FixBot
      Voeg opmerking toe
    2. Parrot Skycontroller 2 Buttons Replacement: stap 2, afbeelding 1 van 1
      • Remove one 9mm screw using a #4 flathead screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    3. Parrot Skycontroller 2 Buttons Replacement: stap 3, afbeelding 1 van 3 Parrot Skycontroller 2 Buttons Replacement: stap 3, afbeelding 2 van 3 Parrot Skycontroller 2 Buttons Replacement: stap 3, afbeelding 3 van 3
      • Insert the plastic opening tool into the top of the cover and pry upwards to lift the battery cover.
      • Remove the cover by pulling up and out.
      Vraag FixBot
      Voeg opmerking toe
    4. Parrot Skycontroller 2 Buttons Replacement: stap 4, afbeelding 1 van 3 Parrot Skycontroller 2 Buttons Replacement: stap 4, afbeelding 2 van 3 Parrot Skycontroller 2 Buttons Replacement: stap 4, afbeelding 3 van 3
      • Pull the connectors out by gently pushing the tabs and pulling up on the connector.
      • Disconnect the battery from the remote by pressing the white tab and pulling the connectors apart.
      Vraag FixBot
      Voeg opmerking toe
    5. Parrot Skycontroller 2 Buttons Replacement: stap 5, afbeelding 1 van 2 Parrot Skycontroller 2 Buttons Replacement: stap 5, afbeelding 2 van 2
      • Remove the battery from its brackets by pulling up on the ends of the battery.
      Vraag FixBot
      Voeg opmerking toe
    1. Parrot Skycontroller 2 Buttons Replacement, Buttons: stap 6, afbeelding 1 van 1
      • Remove the seven black 11mm screws using the Torx TR6 screwdriver.
      • There is a hidden screw located behind the sticker in the battery compartment.
      • Pull back the sticker with your finger nail and remove the one black 11mm screw using the Torx TR6 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Parrot Skycontroller 2 Buttons Replacement: stap 7, afbeelding 1 van 3 Parrot Skycontroller 2 Buttons Replacement: stap 7, afbeelding 2 van 3 Parrot Skycontroller 2 Buttons Replacement: stap 7, afbeelding 3 van 3
      • Remove the seven silver 4mm screws from around the edge of the top plate using the Torx TR6 Screwdriver.
      • The opposite side to the third picture has a screw located on each side of the USB port.
      Vraag FixBot
      Voeg opmerking toe
    3. Parrot Skycontroller 2 Buttons Replacement: stap 8, afbeelding 1 van 1
      • Remove the battery compartment plate by pulling up and out.
      Vraag FixBot
      Voeg opmerking toe
    4. Parrot Skycontroller 2 Buttons Replacement: stap 9, afbeelding 1 van 1
      • Remove the top plate by pushing on the corners with your hand.
      • Be careful to not pull too hard on the cable.
      Vraag FixBot
      Voeg opmerking toe
    5. Parrot Skycontroller 2 Buttons Replacement: stap 10, afbeelding 1 van 2 Parrot Skycontroller 2 Buttons Replacement: stap 10, afbeelding 2 van 2
      • Remove the face plate by pulling up and out.
      • Buttons will fall out when this plate is removed.
      Vraag FixBot
      Voeg opmerking toe
    6. Parrot Skycontroller 2 Buttons Replacement: stap 11, afbeelding 1 van 3 Parrot Skycontroller 2 Buttons Replacement: stap 11, afbeelding 2 van 3 Parrot Skycontroller 2 Buttons Replacement: stap 11, afbeelding 3 van 3
      • Use some force pull up and out on the rubber backing for the buttons.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 27
Altijd: 658
