Ga door naar hoofdinhoud
PDP Afterglow Fener Earpads Replacement
Thomas Williams
Thomas Williams en 5 andere bijdragers
Voor het laatst geüpdatet op December 29, 2022
5 minuten
Gemiddeld
If your PDP Afterglow Fener ear pads are damaged, ripped, or worn down, use this guide for replacement instructions. This guide teaches you how to first remove the ear pads so that they can later be replaced. If you want to complete some inner repairs and simply need access to the ear pieces, you too should use this guide: rather than placing on new pads after completion of this guide, begin repairs on exposed ear pieces instead.
  1. PDP Afterglow Fener Earpads Replacement, Earpads: stap 1, afbeelding 1 van 3 PDP Afterglow Fener Earpads Replacement, Earpads: stap 1, afbeelding 2 van 3 PDP Afterglow Fener Earpads Replacement, Earpads: stap 1, afbeelding 3 van 3
    • Start by removing the right ear pad. Be careful not to pull too hard as it may rip.
    • Gently tug on the pad until it comes free from the slot, which is marked by the red square.
  2. PDP Afterglow Fener Earpads Replacement: stap 2, afbeelding 1 van 3 PDP Afterglow Fener Earpads Replacement: stap 2, afbeelding 2 van 3 PDP Afterglow Fener Earpads Replacement: stap 2, afbeelding 3 van 3
    • Next, repeat step 1 with the left ear pad this time.
  3. PDP Afterglow Fener Earpads Replacement: stap 3, afbeelding 1 van 2 PDP Afterglow Fener Earpads Replacement: stap 3, afbeelding 2 van 2
    • Your headset should now look like this, with the two ear pads removed.
    • You may now continue with a more complex inner headset repair or replace the ear pads by sliding new ones into the slots.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Thomas Williams
512 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015 Lid van UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G3
3 Leden
10 handleidingen geschreven
1 Guide Comment
The problem is not pulling off the earpad, but putting it on again!
peterkd2010 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 14
Altijd: 3,904
