Ga door naar hoofdinhoud
OnePlus 6T Battery Replacement
Wat je nodig hebt
  1. OnePlus 6T Battery Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
    Vraag FixBot
    Voeg opmerking toe
  2. OnePlus 6T Battery Replacement: stap 2, afbeelding 1 van 1
    • Pop open the SIM card tray by inserting a SIM card removal tool into a small hole on the upper-left side of the phone.
    • Carefully remove the SIM card from its tray.
    Vraag FixBot
    Voeg opmerking toe
  3. OnePlus 6T Battery Replacement: stap 3, afbeelding 1 van 1
    • Loosen the binding glue within the phone using a hairdryer or an iOpener.
    • If you choose to use a hairdryer, hold the dryer at least eight inches from the phone and apply heat for two minutes in a circular motion around the edges of the phone.
    Vraag FixBot
    Voeg opmerking toe
  4. OnePlus 6T Battery Replacement: stap 4, afbeelding 1 van 3 OnePlus 6T Battery Replacement: stap 4, afbeelding 2 van 3 OnePlus 6T Battery Replacement: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Plastic Cards
    $2.99
    • Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
    • Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
    • There will be a small amount of tension, but this is normal as the card is removing the adhesive within the phone.
    • Remove the back cover from the phone.
    • Use high concentration (>90%) isopropyl alcohol and a lint-free cloth to remove all adhesive residue from the back cover and the frame.
    Vraag FixBot
    Voeg opmerking toe
  5. OnePlus 6T Battery Replacement, Battery: stap 5, afbeelding 1 van 1
    • Remove the single 3mm Phillips #00 screw from the battery.
    Vraag FixBot
    Voeg opmerking toe
  6. OnePlus 6T Battery Replacement: stap 6, afbeelding 1 van 1
    • Using tweezers, carefully remove the small metal bracket covering the battery connector.
    Vraag FixBot
    Voeg opmerking toe
  7. OnePlus 6T Battery Replacement: stap 7, afbeelding 1 van 1
    Halberd Spudger
    $2.99
    • Using a halberd spudger, gently lift and disconnect the battery connector from the phone.
    • Do not use a metal tool for this step as it may puncture the battery and cause it to leak toxic liquid.
    Vraag FixBot
    Voeg opmerking toe
  8. OnePlus 6T Battery Replacement: stap 8, afbeelding 1 van 2 OnePlus 6T Battery Replacement: stap 8, afbeelding 2 van 2
    • Grab the red tab on the right hand side and pull until the battery dislodges.
    • It will have some tension as there is tape holding the battery in place. Only remove the battery. Make sure to leave the tape as it will ensure the next battery stays in place.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
33 andere personen hebben deze handleiding voltooid.
14Gids Commentaar
Does the adhesive for the back cover need to be replaced? Should I heat the phone and back glass for re-assembly?
Mark Bugajski - Antwoord Deel
Good questions. I think “reassembly is the reverse of these instructions" is a bit simplified. I think the heat is only for removal, but perhaps it would cause the adhesive to rebond after reassembly? Can an ifixit tech comment?
Justin Allen - Antwoord Deel
Just wondering if anyone can clarify the reattachment of the rear panel, as far as whether it is recommended, or necessary, to heat it again, or get a new adhesive gasket. Thanks.
Scott Sparling - Antwoord Deel
Good question! You should replace the back cover adhesive with either a custom-cut adhesive or double-sided tape such as Tesa tape. You can choose to reheat and reuse the existing adhesive, but there may be a chance that the back cover will fall off. If you’re reusing adhesive, be sure to remove any uneven adhesive chunks.
Arthur Shi - Antwoord Deel
What width Tesa tape would work for the replacement of the back cover?
Jamie Wright - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 75
Afgelopen 30 dagen: 374
Altijd: 58,223
