Inleiding
Use this guide to replace a broken or defective AMOLED Screen & Digitizer in your OnePlus 5T.
Note: This guide instructs you to replace only the screen while leaving the original frame and motherboard in place. However, some replacement screens for this phone come pre-installed in a new frame (a.k.a. chassis), which requires a very different procedure. Make sure you have the correct part before starting this guide.
You’ll need replacement adhesive to reattach components when reassembling the device.
Wat je nodig hebt
Try not to remove the backcover all the way yet. The fingerprint and the charging port and headphone flex cables are still connected to the motherboard.
Flip your phone and carefully lift the bottom end of the backcover away from the phone assembly. Fold it to left and hold it at an 80° angle.
Use a spudger to pry up and disconnect the display flex cable.
Apply a heated iOpener to the screen and all edges of the phone for at least two minutes, to loosen the adhesive.
Once the screen is warm to the touch, apply a suction cup to the bottom edge of the phone.
Pull the suction cup upwards and insert an opening pick in the gap between the display glass and the midframe. Start to cut the adhesive by sliding the opening pick to the bottom right corner.
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
10 andere personen hebben deze handleiding voltooid.
Één opmerking
What adhesive do you use? B-7000 glue , 1mm or 2mm adhesive tape?
