Ga door naar hoofdinhoud
Nokia Lumia 1020 Rear-Facing Camera Replacement
Sydney Hostelley
Sydney Hostelley en 2 andere bijdragers
Voor het laatst geüpdatet op June 23, 2022
15 minuten
Moeilijk
Heeft betere plaatjes nodig
Replacing the rear-facing camera of the Nokia Lumia 1020 requires removal of the phone's screen.
Wat je nodig hebt
Gereedschap
Toon meer…
  1. Nokia Lumia 1020 Rear-Facing Camera Replacement, Screen: stap 1, afbeelding 1 van 2 Nokia Lumia 1020 Rear-Facing Camera Replacement, Screen: stap 1, afbeelding 2 van 2
    • Use a SIM door key to remove the SIM card and SIM card tray from the device.
    • Use a T4 screwdriver to loosen the captured torx screw to the right of the SIM card tray (the screw will not come out).
  2. Nokia Lumia 1020 Rear-Facing Camera Replacement: stap 2, afbeelding 1 van 3 Nokia Lumia 1020 Rear-Facing Camera Replacement: stap 2, afbeelding 2 van 3 Nokia Lumia 1020 Rear-Facing Camera Replacement: stap 2, afbeelding 3 van 3
    • Wedge a spudger in between the screen and the back of the device, starting from the top left corner of the phone.
    • Gently pry the screen away from the back of the device using slight upward pressure.
    • Slide the spudger down towards the bottom left corner of the device, continuing to gently pry upwards. The screen will now be slightly separated from the back of the phone.
  3. Nokia Lumia 1020 Rear-Facing Camera Replacement: stap 3, afbeelding 1 van 3 Nokia Lumia 1020 Rear-Facing Camera Replacement: stap 3, afbeelding 2 van 3 Nokia Lumia 1020 Rear-Facing Camera Replacement: stap 3, afbeelding 3 van 3
    • Wedge a spudger underneath the silver rectangle in the upper right corner until it pops off the back of the phone.
  4. Nokia Lumia 1020 Rear-Facing Camera Replacement: stap 4, afbeelding 1 van 3 Nokia Lumia 1020 Rear-Facing Camera Replacement: stap 4, afbeelding 2 van 3 Nokia Lumia 1020 Rear-Facing Camera Replacement: stap 4, afbeelding 3 van 3
    • Wedge a spudger underneath the silver rectangle in the lower left corner until it pops off the back of the phone.
    • Completely remove the screen from the back of the phone.
  5. Nokia Lumia 1020 Rear-Facing Camera Replacement, Rear-Facing Camera: stap 5, afbeelding 1 van 3 Nokia Lumia 1020 Rear-Facing Camera Replacement, Rear-Facing Camera: stap 5, afbeelding 2 van 3 Nokia Lumia 1020 Rear-Facing Camera Replacement, Rear-Facing Camera: stap 5, afbeelding 3 van 3
    • Use your fingernail to grip the rear-facing camera on the upper middle part of the back of the phone. Pry until it pops off to the left.
    • Remove the camera by wedging a spudger underneath the attached gold foil.
Conclusie
Sydney Hostelley
614 Reputatie
5 handleidingen geschreven
USF Tampa, Team S1-G4, Leahy Spring 2018 Lid van USF Tampa, Team S1-G4, Leahy Spring 2018
USFT-LEAHY-S18S1G4
4 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 27
Altijd: 962
