Ga door naar hoofdinhoud
Nokia Asha 201 Audio Jack Replacement
Betsy Walker
Betsy Walker en 4 andere bijdragers
Voor het laatst geüpdatet op June 7, 2023
7 minuten
Gemiddeld
Behoeft meer afbeeldingen
Ontbrekende stappen
Have you ever tried listening to music on your phone with headphones to only hear no sound? Don't want to spent the money to replace the phone in its entirety? Using this guide, you can easily go step by step to replace your Nokia Asha 201 audio jack and get back to listening to the things you love. There are no special skills required for this guide and the only tools you need are an iFixit opening tool and a T6 Torx screwdriver. Instead of buying a brand new phone, use this guide to take matters into your own hands and replace your audio jack yourself!
Wat je nodig hebt
Gereedschap
  1. Nokia Asha 201 Audio Jack Replacement, Audio Jack: stap 1, afbeelding 1 van 1
    • Remove the white case by popping apart the front and back with your finger.
  2. Nokia Asha 201 Audio Jack Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery by taking it out with your fingers.
  3. Nokia Asha 201 Audio Jack Replacement: stap 3, afbeelding 1 van 1
    • Remove the two 5.5mm screws by using the T6 screwdriver.
  4. Nokia Asha 201 Audio Jack Replacement: stap 4, afbeelding 1 van 1
    • Use the blue plastic opening tool to remove the front of the white case.
  5. Nokia Asha 201 Audio Jack Replacement: stap 5, afbeelding 1 van 1
    • Remove the keyboard using your fingers and set aside.
  6. Nokia Asha 201 Audio Jack Replacement: stap 6, afbeelding 1 van 1
    • Unscrew the two 5.5mm screws near the bottom of the device on either side using the T6 screwdriver.
  7. Nokia Asha 201 Audio Jack Replacement: stap 7, afbeelding 1 van 1
    • Separate the black plastic internal case from the screen by prying with the blue plastic opening tool.
  8. Nokia Asha 201 Audio Jack Replacement: stap 8, afbeelding 1 van 1
    • The black plastic cover should now be separated from the motherboard. Replace the audio jack by removing it with your fingers.
Conclusie
Betsy Walker
157 Reputatie
1 Handleiding geschreven
USF Tampa, Team S1-G3, Leahy Fall 2019 Lid van USF Tampa, Team S1-G3, Leahy Fall 2019
USFT-LEAHY-F19S1G3
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 218
