Ga door naar hoofdinhoud
Nintendo Switch Lite Motherboard Replacement
Wat je nodig hebt
  1. Nintendo Switch Lite Motherboard Replacement, Remove the back panel screws: stap 1, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Magnetic Project Mat
    $19.95
    Koop
    • Before beginning this repair, make sure that the device is completely turned off.
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the back panel.
  2. Nintendo Switch Lite Motherboard Replacement, Remove the top and bottom back panel screws: stap 2, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement, Remove the top and bottom back panel screws: stap 2, afbeelding 2 van 2
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following screws securing the back panel:
    • Two 3.6 mm-long screws on the top of the device
    • Two 3.6 mm-long screws on the bottom of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try a different screwdriver if the screws won't come out.
  3. Nintendo Switch Lite Motherboard Replacement, Release the clips securing the back panel: stap 3, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement, Release the clips securing the back panel: stap 3, afbeelding 2 van 2
    • Insert an opening tool into the left speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips securing the back panel.
    • Avoid inserting the opening tool further than required to prevent damage to the speaker module.
  4. Nintendo Switch Lite Motherboard Replacement, Continue releasing the clips around the device: stap 4, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement, Continue releasing the clips around the device: stap 4, afbeelding 2 van 2
    • Slide the opening tool around the bottom-left corner to release the clips on the left side of the device.
  5. Nintendo Switch Lite Motherboard Replacement, Twist to release the clips: stap 5, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement, Twist to release the clips: stap 5, afbeelding 2 van 2
    • Insert an opening tool into the right speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips.
  6. Nintendo Switch Lite Motherboard Replacement, Slide and pry around the corners: stap 6, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement, Slide and pry around the corners: stap 6, afbeelding 2 van 2
    • Slide and pry the opening tool around the bottom-right corner to release the clips on the right side of the device.
  7. Nintendo Switch Lite Motherboard Replacement: stap 7, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Continue sliding and prying the opening tool along the gap on the top of the device to release the clips.
  8. Nintendo Switch Lite Motherboard Replacement, Remove the back panel: stap 8, afbeelding 1 van 3 Nintendo Switch Lite Motherboard Replacement, Remove the back panel: stap 8, afbeelding 2 van 3 Nintendo Switch Lite Motherboard Replacement, Remove the back panel: stap 8, afbeelding 3 van 3
    • Lift the bottom edge of the back panel, opening it like a book.
    • Remove the back panel.
  9. Nintendo Switch Lite Motherboard Replacement, Remove the shield plate: stap 9, afbeelding 1 van 1
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following four screws:
    • Three 3.1 mm screws
    • One 4.5 mm screw
  10. Nintendo Switch Lite Motherboard Replacement: stap 10, afbeelding 1 van 3 Nintendo Switch Lite Motherboard Replacement: stap 10, afbeelding 2 van 3 Nintendo Switch Lite Motherboard Replacement: stap 10, afbeelding 3 van 3
    • Use a spudger or your fingers to lift the shield plate up and out of the device.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • Remove the shield plate.
    • Clean off the old thermal paste from the shield plate and heat sink using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the heat sink before reassembly.
  11. Nintendo Switch Lite Motherboard Replacement, Disconnect the battery: stap 11, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement, Disconnect the battery: stap 11, afbeelding 2 van 2
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the motherboard interconnect cable's ZIF connector.
  12. Nintendo Switch Lite Motherboard Replacement: stap 12, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement: stap 12, afbeelding 2 van 2
    Koop
    • Do Not Use Metal Tweezers! Some fixers state that metallic tweezers can short circuit the ribbon cable/connector. It might be safer to just use nylon-tipped or ceramic-tipped tweezers.
    • Use a pair of tweezers to slide the interconnect cable out of its connector on the motherboard.
  13. Nintendo Switch Lite Motherboard Replacement: stap 13, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement: stap 13, afbeelding 2 van 2
    • Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
  14. Nintendo Switch Lite Motherboard Replacement, Remove the heat sink: stap 14, afbeelding 1 van 1
    • Use the flat end of a spudger or your fingers to carefully peel up the foam that's lightly adhered to the fan.
    • The foam only needs to be peeled back enough to clear the fan.
  15. Nintendo Switch Lite Motherboard Replacement: stap 15, afbeelding 1 van 1
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the three 3 mm screws securing the heat sink to the motherboard.
  16. Nintendo Switch Lite Motherboard Replacement: stap 16, afbeelding 1 van 3 Nintendo Switch Lite Motherboard Replacement: stap 16, afbeelding 2 van 3 Nintendo Switch Lite Motherboard Replacement: stap 16, afbeelding 3 van 3
    • Use a spudger or your fingers to lift the heatsink up and off of the motherboard to remove it.
    • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
    • Clean off the old thermal paste from the heat sink and CPU using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly.
  17. Nintendo Switch Lite Motherboard Replacement, Remove the right trigger button assembly: stap 17, afbeelding 1 van 1
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the two 4.5 mm screws securing the right trigger button assembly to the motherboard.
  18. Nintendo Switch Lite Motherboard Replacement: stap 18, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement: stap 18, afbeelding 2 van 2
    • Remove the right trigger button assembly.
  19. Nintendo Switch Lite Motherboard Replacement: stap 19, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement: stap 19, afbeelding 2 van 2
    Koop
    • Use a pair of tweezers or your fingers to remove the right trigger button assembly's rubber pad if it didn't stay attached to the button assembly.
  20. Nintendo Switch Lite Motherboard Replacement, Disconnect the antenna cables: stap 20, afbeelding 1 van 3 Nintendo Switch Lite Motherboard Replacement, Disconnect the antenna cables: stap 20, afbeelding 2 van 3 Nintendo Switch Lite Motherboard Replacement, Disconnect the antenna cables: stap 20, afbeelding 3 van 3
    • Use the point of a spudger to pry the black antenna cable straight up out of its socket on the motherboard.
    • Repeat the same process for the white antenna cable.
  21. Nintendo Switch Lite Motherboard Replacement, Disconnect the fan cable: stap 21, afbeelding 1 van 1
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the fan cable's ZIF connector.
  22. Nintendo Switch Lite Motherboard Replacement: stap 22, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement: stap 22, afbeelding 2 van 2
    • Use a pair of tweezers to slide out the fan cable from its connector on the motherboard.
  23. Nintendo Switch Lite Motherboard Replacement, Disconnect the screen cable: stap 23, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement, Disconnect the screen cable: stap 23, afbeelding 2 van 2
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the screen cable's ZIF connector.
  24. Nintendo Switch Lite Motherboard Replacement: stap 24, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement: stap 24, afbeelding 2 van 2
    • Use a pair of tweezers to slide the screen cable out of its connector on the motherboard.
  25. Nintendo Switch Lite Motherboard Replacement, Disconnect the digitizer cable: stap 25, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement, Disconnect the digitizer cable: stap 25, afbeelding 2 van 2
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the digitizer cable's ZIF connector.
  26. Nintendo Switch Lite Motherboard Replacement: stap 26, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement: stap 26, afbeelding 2 van 2
    • Use a pair of tweezers to slide the digitizer cable out of its connector on the motherboard.
  27. Nintendo Switch Lite Motherboard Replacement, Disconnect the right joystick cable: stap 27, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement, Disconnect the right joystick cable: stap 27, afbeelding 2 van 2
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the right joystick cable's ZIF connector.
  28. Nintendo Switch Lite Motherboard Replacement: stap 28, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement: stap 28, afbeelding 2 van 2
    • Use a pair of tweezers to slide the right joystick cable out of its connector on the motherboard.
  29. Nintendo Switch Lite Motherboard Replacement, Remove the motherboard assembly: stap 29, afbeelding 1 van 1
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following six screws securing the motherboard:
    • Three 4.5 mm screws
  30. Nintendo Switch Lite Motherboard Replacement: stap 30, afbeelding 1 van 3 Nintendo Switch Lite Motherboard Replacement: stap 30, afbeelding 2 van 3 Nintendo Switch Lite Motherboard Replacement: stap 30, afbeelding 3 van 3
    • Insert a spudger in the gap between the frame and the motherboard and lift the motherboard up and out of its recess.
    • Remove the motherboard assembly.
  31. Nintendo Switch Lite Motherboard Replacement, Remove the right speaker module: stap 31, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement, Remove the right speaker module: stap 31, afbeelding 2 van 2
    Koop
    • Use a pair of tweezers or your fingers to pull the right speaker cable straight up and out of its socket on the motherboard.
  32. Nintendo Switch Lite Motherboard Replacement: stap 32, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement: stap 32, afbeelding 2 van 2
    • Remove the right speaker module from the motherboard.
  33. Nintendo Switch Lite Motherboard Replacement: stap 33, afbeelding 1 van 1
    • Only the motherboard remains.
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Lite Answers community for help.
18 andere personen hebben deze handleiding voltooid.
Craig Lloyd
36.293 Reputatie
82 handleidingen geschreven
5 opmerkingen
Great guide, helped me fix charge port replacement, did notice between 16-17 the card reader magically disappeared, but help me tear down and repair and rebuild with a little bit of head scratching.
Sean Topp - Antwoord
La guida è molto chiara.. ma dove si può acquistare una scheda madre di ricambio ?
Walter - Antwoord
It stops at motherboard removal, is there a section for replacing the USB charging port on the switch lite?
Christian Knight - Antwoord
Where can i get the motherboard from, i cant replace the charging port, cause it is soldered to the motherboard. So if you could please let me know onto where i can get the mother board from. 😊
JoyBoy - Antwoord
I have a working motherboard but it is missing one of the resistors (see the green square). How do I find out the value of this resistor? The resistor is situated to the left of the main chip, just below the microSD card slot, if the USB-C port is facing downward.
Christian Odom - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 36
Afgelopen 7 dagen: 313
Afgelopen 30 dagen: 1,279
Altijd: 43,161
