Ga door naar hoofdinhoud
Nintendo GameCube Controller Rumble Motor Replacement
Wat je nodig hebt
  1. Nintendo GameCube Controller Rumble Motor Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Place the controller (buttons down) on a solid surface.
    • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
    Vraag FixBot
    Voeg opmerking toe
  2. Nintendo GameCube Controller Rumble Motor Replacement: stap 2, afbeelding 1 van 1
    • Gently lift the back panel up, separating it from the front panel.
    • Some of the buttons may fall out if they are knocked around.
    Vraag FixBot
    Voeg opmerking toe
  3. Nintendo GameCube Controller Rumble Motor Replacement, Z Button: stap 3, afbeelding 1 van 2 Nintendo GameCube Controller Rumble Motor Replacement, Z Button: stap 3, afbeelding 2 van 2
    • Grab the Z-button by the peg with tweezers and lift it out of the controller.
    • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
    Vraag FixBot
    Voeg opmerking toe
  4. Nintendo GameCube Controller Rumble Motor Replacement, Circuit Board: stap 4, afbeelding 1 van 1
    • Carefully unhook the cable that is looped around the peg.
    Vraag FixBot
    Voeg opmerking toe
  5. Nintendo GameCube Controller Rumble Motor Replacement: stap 5, afbeelding 1 van 1
    • Lift the circuit board out of the controller.
    • Do not grab the rumble motor to lift the circuit board as shown in the picture. It will in many cases just remove the rumble motor. Instead, grab the edges of the board.
    Vraag FixBot
    Voeg opmerking toe
  6. Nintendo GameCube Controller Rumble Motor Replacement, Rumble Motor: stap 6, afbeelding 1 van 2 Nintendo GameCube Controller Rumble Motor Replacement, Rumble Motor: stap 6, afbeelding 2 van 2
    • Press the tip of the soldering iron against one of the leads and wait until solder is viscous. Carefully pull wire away from lead.
    • Repeat for the second lead and wire.
    • During reassembly, solder the white wire to (+) lead on the right side, and the black wire to the (-) lead on the left side.
    • For more information, please refer to this soldering guide.
    Vraag FixBot
    Voeg opmerking toe
  7. Nintendo GameCube Controller Rumble Motor Replacement: stap 7, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Using tweezers, unhook the wires from the small black bracket keeping them attached to the circuit board.
    Vraag FixBot
    Voeg opmerking toe
  8. Nintendo GameCube Controller Rumble Motor Replacement: stap 8, afbeelding 1 van 1
    • Lift the motor out of the bracket.
    • Remember to not pull by the wires! This can make your repair a lot more complicated.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Sean Michel
2.750 Reputatie
8 handleidingen geschreven
Cal Poly, Team 19-44, Regan Winter 2013 Lid van Cal Poly, Team 19-44, Regan Winter 2013
CPSU-REGAN-W13S19G44
4 Leden
34 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 44
Afgelopen 30 dagen: 164
Altijd: 17,949
