Ga door naar hoofdinhoud
Nintendo 2DS Battery Replacement
Fina Beauchamp
Fina Beauchamp en 9 andere bijdragers
Voor het laatst geüpdatet op March 27, 2023
3 minuten
Eenvoudig
This guide illustrates how to remove the upper rear panel from the Nintendo 2DS to access the battery and other parts of the device.
Wat je nodig hebt
Onderdelen
Gereedschap
Toon meer…
  1. Nintendo 2DS Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the two Phillips captive screws securing the upper rear panel.
    • The captive screws will not completely detach from the back panel.
  2. Nintendo 2DS Battery Replacement: stap 2, afbeelding 1 van 2 Nintendo 2DS Battery Replacement: stap 2, afbeelding 2 van 2
    • Hinge the upper rear panel upwards and outwards to remove it.
  3. Nintendo 2DS Battery Replacement: stap 3, afbeelding 1 van 3 Nintendo 2DS Battery Replacement: stap 3, afbeelding 2 van 3 Nintendo 2DS Battery Replacement: stap 3, afbeelding 3 van 3
    • Remove the battery from its housing by lifting it up from the side closest to the outside edge.
Conclusie
38 andere personen hebben deze handleiding voltooid.
Fina Beauchamp
3.150 Reputatie
6 handleidingen geschreven
Cal Poly, Team 70-1, Forte Winter 2015 Lid van Cal Poly, Team 70-1, Forte Winter 2015
CPSU-FORTE-W15S70G1
4 Leden
35 handleidingen geschreven
5 opmerkingen
The only thing I was trying to figure out is if the bezel came up with the panel, and it’s not clear from these photos. For the record, it does not.
francis deible - Antwoord
This didnt help my problem
Artemy Matveev - Antwoord
maybe its because you did not plug the battery correctly matthew
Ludovic Chartrain - Antwoord
or maybe its just not working ludovic 🫡
Natalia Rabago -
Who knows, will the same battery, instead of 1300mah in original, 2000mah in 'fake' works with 2DS?
Anton Kornilov - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 33
Afgelopen 7 dagen: 213
Afgelopen 30 dagen: 902
Altijd: 48,817
